import arcpy, os, sys, string
from os import path as p
from arcpy import mapping as m
#Make parameters for people to choose mxd and folder of PDFs to compare
maps = r"C:\Users\GIS\Desktop\DDP\mxd\map_book.mxd;C:\Users\GIS\Desktop\DDP\mxd\other_map.mxd"
mxdList = maps.split(";")
pdf_path = r'C:\Users\GIS\Desktop\DDP'
##mxdList = arcpy.GetParameterAsText(0).split(";")
##pdf_path = arcpy.GetParameterAsText(1)
#Use Search Cursor to go through Attribuite Table to get Sheet number info
sheet_count = 0
for mapDoc in mxdList:
arcpy.AddMessage(mapDoc)
print mapDoc
mxd = arcpy.mapping.MapDocument(mapDoc)
max_list = []
for lyr in m.ListLayers(mxd):
try:
rows = arcpy.SearchCursor(lyr)
for row in rows:
max_list.append(row.Sheet_ID)
sheet_count = max(max_list)
print 'Sheet Count: %s' % sheet_count
arcpy.AddMessage('Sheet Count: %s' % sheet_count)
except:
pass
mxdList = arcpy.GetParameterAsText(0).split(';')
sheet_count = ()
print mapDoc
max_list = []
for lyr in m.ListLayers(mxd, "*, Grid"):
try:
for row in rows:
arcpy.AddMessage('Sheet count: %s'%sheet_count)
except:
pass
sheet_count = 0
max_list = []
try:
for row in rows:
except:
pass
arcpy.env.workspace = ws = pdf_path
for pdf_ in arcpy.ListFiles('*.pdf'):
page_list = []
pdf_list = []
pdf = pdf_.split('.')[0].rstrip('0123456789')
for doc in arcpy.ListFiles('%s*.pdf' % pdf):
doc_ = doc.split('.')[0].rstrip('0123456789')
if doc_ == p.basename(mapDoc).split('.')[0]:
page_list.append(int(''.join([i for i in doc if i.isdigit()])))
page_count = max(page_list)
print 'PDF Page Count: %s' %page_count
arcpy.AddMessage('PDF Page Count: %s' %page_count)
if page_count == sheet_count:
arcpy.AddMessage('\n"%s" Sheet Count matches number of pages in %s.pdf\n' %(p.basename(mapDoc),doc_))
print '\n"%s" Sheet Count matches number of pages in %s.pdf\n' %(p.basename(mapDoc),doc_)
else:
arcpy.AddMessage('\n"%s" Sheet Count does not match number of pages in %s.pdf\n' %(p.basename(mapDoc),doc_))
print '\n"%s" Sheet Count does not match number of pages in %s.pdf\n' %(p.basename(mapDoc),doc_)
# MXD LIST
mxd_dict ={}
max_list = []
try:
for row in rows:
mxd_name = p.basename(mapDoc).split('.')[0]
mxd_dict[mxd_name] = sheet_count
except:
pass
# PDF LIST
pdf_dict = {}
pdf_list = []
pdf_list.append(pdf_.split('.')[0].rstrip('0123456789'))
unique = list(set(pdf_list))
for pdf in unique:
page_list = []
for key in mxd_dict.keys():
if doc_ == key:
pdf_dict[doc_] = page_count
# REPORT RESULTS
for pdf in unique:
print 'MXD:\t%s\tSheet Count:\t%s'%(pdf, mxd_dict[pdf])
arcpy.AddMessage('MXD:\t%s\tSheet Count:\t%s'%(pdf, mxd_dict[pdf]))
print 'PDF:\t%s\tPage Count:\t%s'%(pdf, pdf_dict[pdf])
arcpy.AddMessage('PDF:\t%s\tPage Count:\t%s'%(pdf, pdf_dict[pdf]))
if mxd_dict[pdf] == pdf_dict[pdf]:
arcpy.AddMessage('\n"%s.mxd" Sheet Count matches number of pages in %s.pdf\n' %(pdf,pdf))
print '\n"%s.mxd" Sheet Count matches number of pages in %s.pdf\n' %(pdf,pdf)
else:
arcpy.AddMessage('\n"%s.mxd" Sheet Count does not match number of pages in %s.pdf\n' %(pdf,pdf))
print '\n"%s.mxd" Sheet Count does not match number of pages in %s.pdf\n' %(pdf,pdf)
i am getting a exceptions.KeyError'>:u'Amarillo_Base_Map'. Which is wierd where is it getting the u?
The error means this : exception KeyError
Raised when a mapping (dictionary) key is not found in the set of existing keys.
Could it be that there are 22 pdfs and the numbers in the program only go up to 9. So should I make them infinity because Houston has 154 pages.
