I would like use it, but I can`t just copy e value. I tried replace 5 spaces for a broke line; but its doesn`t worked yet. I appreciate a help here. I'm using ArcGIS Desktop 10.4
Best Regards
import os, arcpy, glob
def combinePDFs(out_pdf, pdf_path_or_list):
uses arcpy mapping module to combine pdf documents
out_pdf -- output pdf document (.pdf)
pdf_path_or_list -- list of pdf documents or folder
path containing pdf documents.
# Create new PDF document
out_path, pdf_name = os.path.split(out_pdf)
pdfDoc = arcpy.mapping.PDFDocumentCreate(out_pdf)
# set workspace to get pdfs
if isinstance(pdf_path_or_list, list):
for pdf in pdf_path_or_list:
pdfDoc.appendPages(pdf)
print 'Added "%s" to "%s"' %(pdf, os.path.basename(out_pdf))
elif isinstance(pdf_path_or_list, str):
if os.path.exists(pdf_path_or_list):
# if path, use glob to find all pdf's in folder
for pdf in sorted(glob.glob(os.path.join(pdf_path_or_list, '*.pdf'))):
pdfDoc.appendPages(os.path.join(pdf_path_or_list, pdf))
# Save and close pdf document
pdfDoc.saveAndClose()
del pdfDoc
print 'Created: %s' %out_pdf
return out_pdf if __name__ == '__main__':
# test function with path
out_pdf = r'C:\Users\calebma\Desktop\test.pdf'
path = r'C:\Users\calebma\Desktop\pdfTest'
combinePDFs(out_pdf, path)
# test functino with list
pdf2 = r'C:\Users\calebma\Desktop\test2.pdf'
pdfs = [r'C:\Users\calebma\Desktop\pdfTest\Mailing_Labels5160.pdf',
r'C:\Users\calebma\Desktop\pdfTest\Mailing_Taxpayer.pdf',
r'C:\Users\calebma\Desktop\pdfTest\stfr.pdf']
combinePDFs(pdf2, pdfs)
