Combine: three python scripts and make a one
4785
11-17-2015 09:32 PM
ZiaAhmed
In my previous post, the problem I mentioned I have solved it  using following three python scripts. Is there anyway to combine theses three scripts to make one?
Zia
# Script_01: Create folders with file name
# Zia Ahmed
try:
    import glob, os, shutil
    folder = r"J:\RapidEyr_Atcor\test\HDF"
    for file_path in glob.glob(os.path.join(folder, '*.*')):
        new_dir = file_path.rsplit('.', 1)[0]
        os.mkdir(os.path.join(folder, new_dir))
        shutil.move(file_path, os.path.join(new_dir, os.path.basename(file_path)))
except:
    print "Folder creation failed."
    print arcpy.GetMessages()
# Script_02: Import HDF file as TIFF
# Description: Extract HDF to geotiff
# Zia Ahmed
try:
    import arcpy
    arcpy.env.workspace = r"J:\RapidEyr_Atcor\test\HDF"
    # list all folders in a directory
    folders = arcpy.ListWorkspaces()
    for folder in folders:
        arcpy.env.workspace = folder
        rasterListA = arcpy.ListRasters()
        for raster in rasterListA:
           tifOutA=""+raster[15:46]
           arcpy.ExtractSubDataset_management(raster,tifOutA+"_B1"+".tif", "0")
           arcpy.ExtractSubDataset_management(raster,tifOutA+"_B2"+".tif", "1")
           arcpy.ExtractSubDataset_management(raster,tifOutA+"_B3"+".tif", "2")
           arcpy.ExtractSubDataset_management(raster,tifOutA+"_B4"+".tif", "3")
           arcpy.ExtractSubDataset_management(raster,tifOutA+"_B5"+".tif", "4")
except:
    print "Extract Subdataset failed."
# Scrit_03: Batch processing - Stack RapidEyes bands
# Written by Zia Ahmed, CIMMYT, Bangladeash
try:
    import arcpy, os
    # Define working folder
    arcpy.env.workspace = r'J:\RapidEyr_Atcor\test\HDF'
        # Create a raster list
        rasters = arcpy.ListRasters("*.tif")
        # output file name
        name = os.path.join(rasters[1].split("_")[1] +"_multi"+ ".tif")
        arcpy.CompositeBands_management(rasters, name)
except:
    print "Multiband failed."
Tags (3)
DarrenWiens2
Without fully reading your individual scripts, is there a problem with simply copy/pasting them one after the other into one script?
ModyBuchbinder
Is there any reason not to put all of them in one file and make one script out of them?
DanPatterson_Retired
turn them into functions then call them sequentially.  In this way you can reuse the functions at a later stage.  As a nonsensical example
def a(nums):
    sqrs = [i**2 for i in nums]
    return sqrs
def b(sqrs):
    roots = [i**0.5 for i in sqrs]
    return roots
def c(more):
    final = [i for i in more if i % 2]
    return final
if __name__=="__main__":
    "do stuff with functions"
    nums = [1,2,3]
    sqrs = a(nums)
    roots = b(sqrs)
    final = c(roots)
    frmt = "nums {}  sqrs{}  roots{}  ... final {}"
    print(frmt.format(nums,sqrs,roots,final))
ZiaAhmed
Thanks to all. I will try.
Zia
