Hello - we are migrating to new SDE datasources, and I am trying to make the changes to our mxd's. This is complicated by new names for the geodatabases. My issue now seems to be when saving the mxd's. I have a number of loops, and perhaps the problem is I do not have my indentations correct. In the end, I am not seeing the changes in the mxds. Any suggestions are appreciated!Paul Frank# Author: Paul Frank, City of Austin # Date: November 7, 2012 # Version: ArcGIS 10.0 # Purpose: This script will iterate through each MXD in a folder and change the SDE connection and dataset name. # Then it will save the mxd that it has finished changing. The script is intended to run from a script # tool that requires a parameter with the folder containing MXDs. #setting variables import arcpy, os arcpy.env.overwriteOutput = True print arcpy.GetMessages() #setting variables for new data source and table that lists the old and new dataset names newdatasource = r"C:\Documents and Settings\frankp\Application Data\ESRI\Desktop10.0\ArcCatalog\DataMart.sde" sdechangetable = r"G:\NEIGHBOR PLAN\ArcView\Themes\GIS_Administration\sde_change.dbf" #Read input parameters from GP dialog #folderPath = arcpy.GetParameterAsText(0) folderPath = r"C:\arcinfo\New Folder" try: #Loop through each MXD file for filename in os.listdir(folderPath): fullpath = os.path.join(folderPath, filename) if os.path.isfile(fullpath): if filename.lower().endswith(".mxd"): #Reference MXD mxd = arcpy.mapping.MapDocument(fullpath) arcpy.AddMessage("Changing " + mxd.filePath) print "changing " + mxd.filePath #Reference each data frame and report data DFList = arcpy.mapping.ListDataFrames(mxd) for df in DFList: #Reference each layer in a data frame lyrs = arcpy.mapping.ListLayers(mxd, "", df) for lyr in lyrs: if lyr.isFeatureLayer: olddataset = lyr.datasetName arcpy.AddMessage("Setting " + olddataset) print "Setting " + olddataset rows, row = None,None rows = arcpy.SearchCursor(sdechangetable, "\"OLDSDE\" = " + "'" + olddataset + "'") row = rows.next() #proceed if a match is found in sde layers list if row <> None: newdataset = row.getValue("NEWSDE") arcpy.AddMessage("Changing " + olddataset + " to " + newdatasource + " " + newdataset) print "Changing " + olddataset + " to " + newdatasource + " " + newdataset #attempt to change the datasource. Datasource may not actually exist even if found in list try: lyr.replaceDataSource(newdatasource, "SDE_WORKSPACE", newdataset) lyr.name = newdataset arcpy.AddMessage(olddataset + " changed!") print olddataset + " changed!" except: arcpy.AddError(arcpy.GetMessages(2)) #do not proceed because no match was found in sde layers list else: arcpy.AddMessage("Can not replace " + lyr.name) print "Can not replace " + lyr.name else: arcpy.AddMessage("Trying next layer") print "trying next layer" arcpy.AddMessage("Finished replacing " + filename) mxd.save() arcpy.AddMessage("Saved " + filename) print "saved copy of mxd" del mxd del row del rows del folderPath, fullpath except Exception, e: import traceback map(arcpy.AddError, traceback.format_exc().split("\n")) arcpy.AddError(str(e))
