Change db connection properties of layer files in a folder (SDE to SDE)
3294
8
11-07-2021 11:43 AM
JavadSalimi
I would really appreciate some of you ESRI and Python experts to lend a hand to me on this subject. I have a number of folders that each contain countless layer files (.lyr). All of the layer files reference an old SDE db connection and the task at hand is to change them all to a new SDE connection using Python.
There seems to be a lot of forum submissions describing a similar requirement but not ending well due to some limitations with objects or python, or some combination thereof. I am hoping to get any insight at this point. A lot of examples involve changing the data connection prooperties of layers in a map (.mxd), but in my case, they are not managed this way...they're in file folders.
Something along the lines of:
for every layer file in a folder change the db connection from SDE1 to SDE2
DanPatterson
MVP Esteemed Contributor
Updating and fixing data sources—ArcGIS Pro | Documentation would this be what you are referring to?
... sort of retired...
JavadSalimi
Thanks for taking the time to reply Dan.
I actually experimented with the suggestions on the link you provided. However I am hoping to stick with .lyr files. The apps  dependant on the layer files may not be able to handle .lyrx files.
tigerwoulds
You can try something like within your for loop
lyr.findAndReplaceWorkspacePath(find_workspace_path=lyr.dataSource, replace_workspace_path=r"C:\Newpath\To\SDE_ConnectionFile.sde")
Lots of examples here: Desktop Help 10.0 - Updating and fixing data sources with arcpy.mapping (arcgis.com)
JavadSalimi
Thank you for the response.
There is some promise here. I have the following so far but after the "for", only the print line works, the others return the error "AttributeError: 'unicode' object has no attribute 'findAndReplaceWorkspacePath'".
import arcpy
import os
arcpy.env.workspace = r"\\...\layerfiletest"
lyrFileList = arcpy.ListFiles("*.lyr")
for lyr in lyrFileList:
            #print lyrFile
            #lyr.findAndReplaceWorkspacePaths(r"\\...User.sde", r"\\...User.sde")
            #lyr.findAndReplaceWorkspacePath(find_workspace_path=lyr.dataSource, replace_workspace_path=r"\\...User.sde")
            #lyr.findAndReplaceWorkspacePath(lyr.dataSource, r"\\...User.sde")
DanPatterson
python isn't going to understand your path  r"\\...User.sde"
the error is in the path name, so you will have to provide it or check for spaces, international characters, punctuation and the like
JavadSalimi
Sorry to confuse the matter. I have a proper path but just tried hiding it. Please assume they are correct.
tigerwoulds
If you can post the full code you are using (change folder and drive letter names if you want) that is a better option. You can also try lyr.replaceDataSource
JavadSalimi
I don't have much more but, for clarity I have posted with the full paths:
import arcpy
import os
folderpathLayerFiles = r"\\corp\roaming\redirected\jds\Desktop\test\layerfiletest2"
           #print lyrFile
           #lyr = arcpy.mapping.Layer(os.path.join(folderpathLayerFiles,lyrFile))
           #print lyr.dataSource
           #lyr.findAndReplaceWorkspacePath(find_workspace_path=lyr.dataSource,    replace_workspace_path=r"\\server\gis_work\GIS_Layers\Connection File\[email protected]")
          #lyr.findAndReplaceWorkspacePath(lyr.dataSource, r"\\server\gis_w\GIS_Layers\Connection File\[email protected]")
          #lyr.findAndReplaceWorkspacePath(r"\\server\gis_w\GIS_Layers\[email protected]", r"\\server\gis_work\GIS_Layers\Connection File\[email protected]")
I tried lyr.replaceDataSource as well but go the same error.
