Can you input a parameter value after starting a script tool?
5646
11
10-26-2021 12:25 PM
tigerwoulds
I have a python script that will edit all map service capabilities for all services on a federated GIS Server. The script will print out a list of GIS Servers in a federated Enterprise environment > prompt the user to input an integer associated with the index of which GIS Server they want to operate on > all map services are updated on that server.
I am trying to convert this to a script tool in ArcGIS Pro. My script requires the user to input a value after it prints the list of GIS Servers, so it knows which server to run the remaining script on. Is this possible using a script tool? If so, how can I do this?
tigerwoulds
I need the the index of the GIS Server the user selects as a variable to use later on in my execute. Using parameters[3].valueAsText  does not provide this.
I did figure this out though, so thank you for you help!
def execute(self, parameters, messages):
"""The source code of the tool."""
# Input Parameters
startTime = time.time()
portal = parameters[0].valueAsText
user = parameters[1].valueAsText
password = parameters[2].valueAsText
# Based on which server the user selects for the GIS Server drop down, get the Index Number for that to pass into the rest of the script
if parameters[2].value: # If the password field is filled in
gis = GIS(portal, user, password, verify_cert=False) # Connect to the GIS Portal
serverList = gis.admin.servers.list() # Build a list of GIS Servers
# Convert each item in the serverList to a string and add it to a new list
newList = []
for item in serverList:
myString = str(item)
newList.append(myString)
x = newList.index(parameters[3].valueAsText) # Get index value from the server list based on which server the user selects
by Anonymous User
Not applicable
If you need the index for other things in your code, you can create a 'read-only' kind of parameter parameters[4](?) and set it when you get the index.
