Post the rest of the script?
Hey Ian. Large script and would prefer not to post everything. Here is what I believe to be pertinent tho...
def get_Coordinates():
#Create SQL statement
where_clause_envelope = "\"{}\" = '{}'" "or " "\"{}\" = '{}'".format(Field,originValue,Field,destValue)#produces: "Name" = 'Amarillo 34th St'or "Name" = 'Coulter
#Create temp layer for origin and destination
Ends = arcpy.MakeFeatureLayer_management(subs, "Ends", where_clause_envelope)
fields = ["SHAPE@X","SHAPE@Y"]
cursor = arcpy.da.SearchCursor(Ends, fields)
record1 = next(cursor)
record2 = next(cursor)
x1 = record1[0]
x2 = record2[0]
y1 = record1[1]
y2 = record2[1]
pointList = [arcpy.Point(x1, y1),
arcpy.Point(x2,y2)]
return pointList
def get_costRaster(count):
return os.path.join(savepath + "\\Scratch.gdb" + "\\cost_Raster_" + str(count))
savepath = r"G:\Xcel\Route Tool\Southwest\AMA_S_2_PD"
End_Raster = os.path.join(savepath + "\\Scratch.gdb" + "\\End_Raster_" + str(count))
# The following inputs are layers or table views: "dist_Raster_0"
outPointExtract = ExtractByPoints(get_costRaster(count),pointList,"INSIDE")
outPointExtract.save(End_Raster)
