Can anyone tell me what this error means?
1649
06-30-2014 01:38 PM
NoahHuntington
I recieve the following message well into the script.  Several dtasets have already been saved to this workspace.  This is the only place to script fails.  dist_Raster_0 also exists in the workspace and is not empty. Any ideas?
ExecuteError: ERROR 999999: Error executing function.
The table was not found. [VAT_dist_Raster_0]
ERROR 010060: Could not open and write to c:\windows\system32\poi011.
Failed to execute (ExtractByPoints).
AndrewChapkowski
NoahHuntington
Thanks Andrew for chiming in.  I have looked at this and seems to suggest there is a schema lock or similar on the input raster.  I can't imagine why this would be true.  Interesting enough I can run the same script hardcoded in the IDE without this error?  However when I try running dynamically through a custm tool the error occurs.  Any thoughts?
IanMurray
Honored Contributor
Post the rest of the script?
NoahHuntington
Hey Ian.  Large script and would prefer not to post everything.  Here is what I believe to be pertinent tho...
def get_Coordinates():
    #Create SQL statement
    where_clause_envelope =  "\"{}\" = '{}'" "or " "\"{}\" = '{}'".format(Field,originValue,Field,destValue)#produces: "Name" = 'Amarillo 34th St'or "Name" = 'Coulter
    #Create temp layer for origin and destination
    Ends = arcpy.MakeFeatureLayer_management(subs, "Ends", where_clause_envelope)
    fields = ["SHAPE@X","SHAPE@Y"]
    cursor = arcpy.da.SearchCursor(Ends, fields)
    record1 = next(cursor)
    record2 = next(cursor)
    x1 = record1[0]
    x2 = record2[0]
    y1 = record1[1]
    y2 = record2[1]
    pointList = [arcpy.Point(x1, y1),
         arcpy.Point(x2,y2)]
    return pointList
def get_costRaster(count):
    return os.path.join(savepath  + "\\Scratch.gdb"  + "\\cost_Raster_" + str(count))
savepath = r"G:\Xcel\Route Tool\Southwest\AMA_S_2_PD"
End_Raster =  os.path.join(savepath  + "\\Scratch.gdb"  + "\\End_Raster_" + str(count))
# The following inputs are layers or table views: "dist_Raster_0"
outPointExtract = ExtractByPoints(get_costRaster(count),pointList,"INSIDE")
outPointExtract.save(End_Raster)
