Calculate geometry leads to KeyError: '#'
2870
04-30-2022 02:58 PM
kradijaf
import arcpy as a
a.env.overwriteOutput=1
a.env.workspace=r'F:\route\to\database\database.gbd'
a.management.MakeFeatureLayer('feature_class', 'feature_layer')
a.CalculateGeometryAttributes_management('feature_layer', ["new_field", "AREA_GEODESIC"], area_unit="SQUARE_KILOMETERS")
Tried to calculate it with both arcpy.management.CalculateGeometryAttribute and arcpy.CalculateGeometryAttributes_management as in https://pro.arcgis.com/en/pro-app/latest/tool-reference/data-management/calculate-geometry-attribute... always led to:
KeyError: '#',
Failed to execute (CalculateGeometryAttributes),
geomValue = eval(geomCalcs[calcProp[1].upper()]).
I´m using PythonWin 3.7.11 and ArcGIS Pro 2.9.0
I read this thread, checked my code again, didn't help. https://community.esri.com/t5/python-questions/keyerror-when-calculating-geometry-in-arcpy/td-p/1030...
DanPatterson
MVP Esteemed Contributor
Where are
defined?
CalculateGeometryAttributes(in_features, geometry_property, {Length_Unit}, {Area_Unit}, {Coordinate_System}
The parameters don't include field names
... sort of retired...
kradijaf
'feature_class', 'feature_layer' are not variables, 'feature_class' exists in .gdb. Not sure I understand what you mean with "The parameters don't include field names", field name should be 1st part of 2nd parameter.a
DanPatterson
the help shows a list of lists, whereas an exported run shows a semi-colon delimited string.  maybe they are interchangeable
one field
arcpy.management.CalculateGeometryAttributes("pnts", "xs POINT_X", '', '', None, "SAME_AS_INPUT")
two fields
arcpy.management.CalculateGeometryAttributes("pnts", "xs POINT_X;ys POINT_Y", '', '', None, "SAME_AS_INPUT")
try [["new_field", "AREA_GEODESIC"]] since the help shows a list enclosed in a list for multiple parameters, perhaps it needs the enclosing list even if one is chosen
JoshuaBixby
arcpy.CalculateGeometryAttributes_management is simply an alias for arcpy.management.CalculateGeometryAttributes, so you should never get different results between them.  If you do get different results, there is a ArcPy defect somewhere.
According to the documentation you reference, the geometry_property parameter should be in the form of a Value Table, which is one form of a multi-value input.  Working with multivalue inputs—ArcGIS Pro | Documentation .  Working with Value Table objects is quite clunky, so there are Python list and string representations of them, which is what you commonly see in documentation examples.
