Calculate Geometry Attributes causing AttributeError
6661
11
01-10-2024 10:13 AM
Christian_Kennedy
Hello!
I am currently trying to create a script to automate parcel updates. I built the original script in a Notebook that works perfectly fine in Pro but now that I am trying to recreate it as a stand-alone script, I am running into some hiccups. My current sticking point is trying to calculate geometry attributes. It is coming back with the error: AttributeError: 'module' object has no attribute 'CalculateGeometryAttributes'
I have tried a couple of things based on what I have found on the web pertaining to this error. First, I tried using arcpy.CalculateGeometryAttributes_management instead of arcpy.management.CalculateGeometryAttributes but no luck.
I then tried to create a variable for the parameters since there is so much text and that also did not work.
I am able to run the geoprocessing tool in Pro once the layers have been created with the script, the tool just isn't working in the script.
Any thoughts?
Here is how I have it set up in the script:
arcpy.CalculateGeometryAttributes_management(out_data_py,
"ACRE AREA",
"ACRES",
'PROJCS["NAD_1983_StatePlane_Kansas_North_FIPS_1501_Feet",GEOGCS["GCS_North_American_1983",DATUM["D_North_American_1983",SPHEROID["GRS_1980",6378137.0,298.257222101]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]],PROJECTION["Lambert_Conformal_Conic"],PARAMETER["False_Easting",1312333.333333333],PARAMETER["False_Northing",0.0],PARAMETER["Central_Meridian",-98.0],PARAMETER["Standard_Parallel_1",38.71666666666667],PARAMETER["Standard_Parallel_2",39.78333333333333],PARAMETER["Latitude_Of_Origin",38.33333333333334],UNIT["Foot_US",0.3048006096012192]]',
"SAME_AS_INPUT")
print("Acreage Calculated")
I am fairly new to writing Python scripts for automation so I apologize if this isn't very clear or if I haven't included enough info. It's a fairly long script (for me) so I didn't want to share a bunch of superfluous text but if it's needed, I can add more for context. Thank you for looking!
Christian_Kennedy
I figured it out! I THOUGHT I was running the same Python environment as Pro but I was running the Python env for ArcMap! Ugggghhhhh...I had checked but was not thorough enough apparently. But it's fixed and it's working now. Good gravy, what a relief.
HowardJohnston
Hi Christian, I am having the same issues, would you mind explaining how you set the python environment as Pro.
