blue outline on maps from arcpy.searchcursor
6689
12-04-2015 12:01 PM
PaulFrank
Hello,
Perhaps this is really an Arcmap question, but I am using arcpy.searchcursor to find new records, perform a definition query on a polygon, and create maps from the polygon outline.  Everything works as intended except after the first map, subsequent maps have a polygon with the blue selection outline.  Ive tried a few things to eliminate this.  One workaround I have considered is creating a new layer from the definition query, and removing the old layer.  I have also changed the options in Arcmap to not use blue as a selection color.
I suppose this has something to do with the searchcursor, but I am not sure how to get around that.
Thanks for looking
Paul Frank
Tags (3)
DarrenWiens2
Without inspecting your script, have you run (or considered running) Select Layer By Attribute, specifying CLEAR_SELECTION as the selection method, to remove the selection from your layer?
DarrenWiens2
PaulFrank
Darren,
You helped me figure it out.  I did have the code you suggested but I got to thinking it still had something to do with the surchcursor.  It turns out I needed to move on to the next record before exporting the map, as opposed to after, which is how I had it.
Thanks!
DarrenWiens2
Glad you figured it out. As a postscript, if you're interested and using 10.1+ (I think), you may want to look into using arcpy.da.SearchCursor(). They're faster and don't require "nexting".
PaulFrank
Darren,
Now I think you were correct the first time.  I ran it again and my fix didn't work.  So then I looked at it again, and I am using 2 versions of the same layer in this mxd, so I went back and added your code to the other layer, and everything looks correct now.  I am still a little foggy on what is going on but it seems to work.  Again, thanks!
