Basic OD Cost Matrix script not working (error 000732)
1237
05-21-2012 04:31 AM
TheophileEmmanouilidis
Dear all,
I've been using modelbuilder to create a basic model of an OD Cost Matrix analysis. I exported it to a python script to create script tool (code below). Unfortunately I keep getting the following error:
"ERROR 000732: Input network analysis layer: Dataset C:\GIS\databases\fullnetwork.gdb\fullnetwork\fullnetwork_ND does not exist or is not supported."
I've also tried "C:/GIS/databases/fullnetwork.gdb/fullnetwork/fullnetwork_ND" but i got the same error.
The model has 4 required parameters (script tool parameters):
- Network / Network Dataset / Input
- Origins / Feature Class / Input
- Destinations / Feature Class / Input
- NA_Output / Feature Class / Output
I really don't understand what I am doing wrong... any advice welcome 🙂
Best regards,
Theo
[PHP]
# OD_COST_PYTHON_Brut3.py
# Created on: 2012-05-21 13:42:11.00000
#   (generated by ArcGIS/ModelBuilder)
# Usage: OD_COST_PYTHON_Brut3 <fullnetwork_ND__2_> <Origin_feature_points> <Destination_feature_points> <line_feature_output>
# Description:
# Set the necessary product code
# import arcinfo
# Import arcpy module
import arcpy
# Check out any necessary licenses
arcpy.CheckOutExtension("Network")
# Script arguments
fullnetwork_ND__2_ = arcpy.GetParameterAsText(0)
if fullnetwork_ND__2_ == '#' or not fullnetwork_ND__2_:
    fullnetwork_ND__2_ = "fullnetwork_ND" # provide a default value if unspecified
Origin_feature_points = arcpy.GetParameterAsText(1)
if Origin_feature_points == '#' or not Origin_feature_points:
    Origin_feature_points = "oioiuiuo_origins" # provide a default value if unspecified
Destination_feature_points = arcpy.GetParameterAsText(2)
if Destination_feature_points == '#' or not Destination_feature_points:
    Destination_feature_points = "oioiuiuo_origins" # provide a default value if unspecified
line_feature_output = arcpy.GetParameterAsText(3)
if line_feature_output == '#' or not line_feature_output:
    line_feature_output = "D:\\pythonproject\\premierpas\\databases\\scratch.gdb\\odout" # provide a default value if unspecified
# Local variables:
Destinations = "OD Cost Matrix\\Destinations"
OD_Cost_Matrix__3_ = Origin_feature_points
OD_Cost_Matrix__5_ = OD_Cost_Matrix__3_
OD_Cost_Matrix__2_ = OD_Cost_Matrix__5_
OD_Cost_Matrix__6_ = OD_Cost_Matrix__2_
Lines = OD_Cost_Matrix__6_
Lines__3_ = Lines
Lines__4_ = Lines__3_
Solve_succeeded = OD_Cost_Matrix__2_
Origins = "OD Cost Matrix\\Origins"
OD_Cost_Matrix = fullnetwork_ND__2_
OD_Cost_Matrix__4_ = OD_Cost_Matrix
# Process: Make OD Cost Matrix Layer
arcpy.MakeODCostMatrixLayer_na(fullnetwork_ND__2_, "OD Cost Matrix", "Length", "", "", "", "ALLOW_UTURNS", "", "NO_HIERARCHY", "", "STRAIGHT_LINES")
# Process: Add Field to Analysis Layer
arcpy.AddFieldToAnalysisLayer_na(OD_Cost_Matrix, "Origins", "OriginAddressID", "LONG", "", "", "", "", "NULLABLE")
# Process: Add Locations
arcpy.AddLocations_na(OD_Cost_Matrix__4_, "Origins", Origin_feature_points, "Name OBJECTID #;TargetDestinationCount # #;CurbApproach # 0;Cutoff_Length # #;OriginAddressID OBJECTID #;SourceID SourceID #;SourceOID SourceOID #;PosAlong PosAlong #;SideOfEdge SideOfEdge #", "5000 Meters", "", "NetworkFull SHAPE;fullnetwork_ND_Junctions NONE", "MATCH_TO_CLOSEST", "APPEND", "NO_SNAP", "5 Meters", "INCLUDE", "NetworkFull #;fullnetwork_ND_Junctions #")
# Process: Add Field to Analysis Layer (2)
arcpy.AddFieldToAnalysisLayer_na(OD_Cost_Matrix__3_, "Destinations", "DestinationAddressID", "LONG", "", "", "", "", "NULLABLE")
# Process: Add Locations (2)
arcpy.AddLocations_na(OD_Cost_Matrix__5_, "Destinations", Destination_feature_points, "Name OBJECTID #;CurbApproach # 0;DestinationAddressID OBJECTID #;SourceID SourceID #;SourceOID SourceOID #;PosAlong PosAlong #;SideOfEdge SideOfEdge #", "5000 Meters", "", "NetworkFull SHAPE;fullnetwork_ND_Junctions NONE", "MATCH_TO_CLOSEST", "CLEAR", "NO_SNAP", "5 Meters", "INCLUDE", "NetworkFull #;fullnetwork_ND_Junctions #")
# Process: Solve
arcpy.Solve_na(OD_Cost_Matrix__2_, "SKIP", "CONTINUE")
# Process: Select Data
arcpy.SelectData_management(OD_Cost_Matrix__6_, "Lines")
# Process: Join Field
arcpy.JoinField_management(Lines, "DestinationID", Destinations, "OBJECTID", "DestinationAddressID")
# Process: Join Field (2)
arcpy.JoinField_management(Lines__3_, "OriginID", Origins, "OBJECTID", "OriginAddressID")
# Process: Copy Features
arcpy.CopyFeatures_management(Lines__4_, line_feature_output, "", "0", "0", "0")
[/PHP]
curtvprice
Make sure your parameter definitions match what you were using for your model. For example, it looks like (from the defaults) that your first argument was a feature layer, not a feature dataset.  A way to check this is to open the source model, right click the parameters, and see what data type they are. Your script tool parameter properties should use the same data types.
