Automate sharing of multiple Imagery Layers from geodatabase with ArcPy
1384
06-19-2023 12:17 AM
KarolWitkowski
Hello,
I've read a lot of documentation and scripts about layer sharing, but I haven't found a clear answer to my question, namely - how to easily automate the sharing of layers (in my case they are mosaic datasets located in a professional geodatabase) on ArcGIS Enterprise (on image server) using Python.
I have a lot of mosaic datasets and I will be happy if I can automate the process of sharing them.
I found some tips on how to share hosted layers and tried to translate this into my problem (wants to share them as registered source data without copying them to the portal), but in some places I didn't clearly understand how it works.
I would appreciate any help
AngelaSchirck
I have a similar issue but with feature layers (not hosted).  I too have found a LOT of confusing information and have yet to figure it out, but the processes should be similar.  Let me know if you figure this out.
KarolWitkowski
I haven't been able to find a solution to my problem so far
I will try maybe to ask esri technical suport for help
