arcpy.UpdateCursor setting a row value to null instead of 0
6538
09-23-2015 03:42 PM
ShaneArmour
I'm having issues setting a row value to 0 when joining a csv to a shapefile. When the shapefile value is not in the csv, the row is getting set to 0 instead of null. This is a huge problem as i'm showing 0 change instead of no data. I tried row.setValue(field, None) and row.setNull(field) and both produce the same result. In the .dbf file of the shapefile, there is no value but in the UI attribute table a 0 is shown. Any advice on how to fix this would be very appreciated.
Thanks!
Shane
    arcpy.AddField_management(shpfile, "TEST", "DOUBLE", field_is_nullable = 'NULLABLE')
    newcols = ["TEST"]
    with open(csvfile, 'rb') as csvfile:
        lib = dict()
        csvfile = csv.reader(csvfile, delimiter = ",")
        csvfile.next() #skip the headers
        for line in csvfile:
            lib[line[csvjoinindex]] = lib.get(line[csvjoinindex],line[csvstartfield:])
    rows = arcpy.UpdateCursor(shpfile)
    for row in rows:
        shpjoinval = str(row.getValue(shapefilejoincol))
        try:
            vals = lib.get(shpjoinval)
            for ind, field in enumerate(newcols):
                row.setValue(str(field),vals[ind])
                rows.updateRow(row)
        except:
                 row.setNull(field)
                 rows.updateRow(row)
FreddieGibson
Honored Contributor
You'd need to use a geodatabase feature class instead of a shapefile to accomplish this. Shapefiles do not support NULL values. This is documented on the following page:
Add Field (Data Management)
http://desktop.arcgis.com/en/desktop/latest/tools/data-management-toolbox/add-field.htm
As shown in the screenshot below, Null values are only supported for fields in a geodatabase.
DanPatterson_Retired
specifics to shapefiles regarding nulls or lack thereof
Data type containing null valueNull value substitution
Number—When tool requires that a NULL, infinity, or NaN (Not a Number) be output
-1.7976931348623158e+308 (IEEE standard for the maximum negative value)
Number (all other geoprocessing tools)
Text
" " (blank—no space)
Date
Stored as zero, but displays <null>
from here  Geoprocessing considerations for shapefile output—Help | ArcGIS for Desktop
