arcpy: table is not editable
1753
07-09-2021 08:21 AM
MatthiasHa
Hello,
I just tried to edit a shapefile inside python, but all I get is ERROR 000499: table is not editable. The strange thing is: I can edit the shapefile in arcMap, it just wont work with arcpy. Also after I restarted my computer (so there is no lock on the file... ) Here's the code:
import arcpy
workspace = "W:/data/"
arcpy.env.workspace = workspace
filename = "measurePoints"
arcpy.Copy_management(fileName + ".shp", fileName + "XY.shp")
with arcpy.da.Editor(workspace) as edit:
	arcpy.AddXY_management(fileName + "XY.shp")
 I checked if the file is write-protected, but it isn't, since I just create it in the code.
If anybody has any ideas, I'd appreciate it very much!
best regards!
DanPatterson
MVP Esteemed Contributor
Did you try...
... sort of retired...
DanPatterson
Did you try...
MatthiasHa
Ahh now I see my mistake...
Thank you!
