arcpy.mp update LegendElement's map frame
1900
09-11-2020 12:24 PM
CM1
In the Python arcpy.mp module, the LegendElement class (LegendElement—ArcGIS Pro | Documentation ) states that the mapFrame property is read/write but I am getting a value error when trying to assign it a map frame object.  My end goal is to try to swap the map a given legend is referencing.  Am I doing something wrong or is this a bug?
Example:
Thank you.
DanPatterson
MVP Esteemed Contributor
can you show the relevant code?
... sort of retired...
CM1
Issue resolved, not sure what was going on in my attached image RE the type error given that m: MapFrame and legend: Legend.  Re-tried this in a fresh session today though and things worked as intended.  May have just gotten variables mixed up in the Python console.
