arcpy.JSONToFeatures_conversion
2829
6
03-02-2022 08:50 AM
JamesCrandall
Can anyone spot the issue with this input .json file?
arcpy.JSONToFeatures_conversion fails in both a .py script and in ArcGIS Desktop 10.8.1 JSONToFeatures toolbox.
py script error: "EOFError: [Errno 10054] An existing connection was forcibly closed by the remote host"
Toolbox error: no message specified but the process fails with the Background Processing window appearing stating the operations did not complete successfully due to error and to tell ESRI's GP team about it.
  "features": [
        "geometry": {
          "y": -81.3515715,
          "x": 27.941971
        "attributes": {
          "location_timestamp": 1646081377,
          "vehicleName": "Truck1",
          "deviceId": "350200694388663"
        "geometry": {
          "y": -81.3515715,
          "x": 27.941971
        "attributes": {
          "location_timestamp": 1646081388,
  "fieldAliases": {
    "location_timestamp": "location_timestamp",
    "vehicleName": "vehicleName",
    "deviceId": "deviceId",
    "OBJECTID": "OBJECTID"
  "fields": [
      "alias": "OBJECTID",
      "type": "esriFieldTypeOID",
      "name": "OBJECTID"
      "alias": "deviceId",
      "length": 50,
      "type": "esriFieldTypeString",
      "name": "deviceId"
      "alias": "vehicleName",
      "length": 50,
      "name": "vehicleName"
      "alias": "location_timestamp",
      "length": 8,
      "type": "esriFieldTypeDate",
      "name": "location_timestamp"
  "displayFieldName": "vehicleName",
  "spatialReference": {
    "wkid": 102100,
    "latestWkid": 3857
  "geometryType": "esriGeometryPoint"
DavidPike
MVP Notable Contributor
not sure about the extra set of square brackets on "features":
	"features": [{
			"geometry": {
				"y": -81.3515715,
				"x": 27.941971
			"attributes": {
			"geometry": {
				"y": -81.3515715,
				"x": 27.941971
			"attributes": {
	"fieldAliases": {
	"fields": [{
			"name": "OBJECTID"
			"length": 50,
			"name": "deviceId"
			"length": 50,
			"length": 8,
		"wkid": 102100,
		"latestWkid": 3857
DavidPike
	"features": [{
			"geometry": {
				"y": -81.3515715,
				"x": 27.941971
			"attributes": {
			"geometry": {
				"y": -81.3515715,
				"x": 27.941971
			"attributes": {
	"fieldAliases": {
	"fields": [{
			"name": "OBJECTID"
			"length": 50,
			"name": "deviceId"
			"length": 50,
			"length": 8,
		"wkid": 102100,
		"latestWkid": 3857
JamesCrandall
Good eye.  Thank you!
I'm attempting to transform a XML response from a non-spatial api that I've got to basically rebuild into well-formatted json and it looks like I've got an improper list-build process going on somewhere that generates the json.  Your correction looks like it should work.
DavidPike
JSON drives me nuts.  Maybe ambitious to mark it as correct if not tested!
JamesCrandall
Well... if you're up to taking a stab at my list-build problem I can keep this thread going!  🙂
DavidPike
Ah if it works as a step in a bigger problem I'll keep the solve.  Probably better to do a new thread for a new problem.  Would get more interaction also.
JamesCrandall
heh.... No problem.  Actually I think I've worked it out.  But yep my squigglies perception is about maxed out for the day!
Thanks for the answer it helped.
