arcpy.ia.Colormap is not working on the .tif file or cannot be save by save method.
2227
12-02-2021 10:16 PM
ElizabetJaneRoot
Hi team,
I'm trying to use arcpy.ia.Colormap function to change the color of Tiff file that is reclassified by arply.sas.Reclassify function.
After I execute the function, it doesn't show the error but when I tried to save by save method of Raster object, it gives an error back.
recolored.save(save_path)
RuntimeError: Unspecified error
but when I use the code below to the Tiff dataset, it can be recolored with no errors.
arcpy.management.AddColormap(save_path, "#", colormap)
I have attached Tiff image as zip file that supposed to be pointed at save_path
DanPatterson
MVP Esteemed Contributor
did you try
Copy Raster (Data Management)—ArcGIS Pro | Documentation
and experiment with the Colormap to RGB parameter
... sort of retired...
DanPatterson
did you try
ElizabetJaneRoot
Thanks for the comment!
