arcpy function to calculate angle between two lines
5706
6
02-23-2011 06:20 AM
CrispinCooper
Does this exist?
Thanks, C.
ChrisSnyder
Honored Contributor
You can make rapid coordinate system conversions by using an appropriate spatial reference parameter in a cursor. For example, this code spits out the vertice coordinates of a township layer in WGS84 coordinates (not their native StatePlane coordinates).
import arcgisscripting
gp = arcgisscripting.create(9.3)
fc = r"\\snarf\am\div_lm\ds\gis\tools\sde_connections_read\ropa_gis_layer_user.sde\CADASTRE.TOWNSHIP_SV"
spatialRef = r"C:\Program Files\ArcGIS\Coordinate Systems\Geographic Coordinate Systems\World\WGS 1984.prj"
dsc = gp.describe(fc)
shapeFieldName = dsc.shapeFieldName
oidFieldName = dsc.oidfieldname
searchRows = gp.searchcursor(fc, "", spatialRef)
searchRow = searchRows.next()
while searchRow:
    oidFieldValue = searchRow.getvalue(oidFieldName)
    print oidFieldName + " = " + str(oidFieldValue)
    shapeFieldObj = searchRow.getvalue(shapeFieldName)
    partCount = shapeFieldObj.partcount
    partIndex = 0
    while partIndex < partCount:
        print "Part " + str(partIndex)+ ":"
        partObj = shapeFieldObj.GetPart(partIndex)
        pointObj = partObj.next()
        pointCounter = 0
        while pointObj:
            print pointObj.x, pointObj.y
            pointCounter += 1
            # If pointObj is null, either the part is finished or there is an interior ring
            if not pointObj:
                if pointObj:
                    print "Interior Ring:"
        partIndex += 1
ChrisMathers
Not that I know of but you could get the geometry object to each, find their angles and calculate it that way. That would be a kind of  brute force way of doing it though.
CrispinCooper
Hi, thanks for the replies.
My second best option is to get the geometry for each and calculate manually.  Some variant on atan(dy1/dx1)-atan(dy2-dx2) will work for the planar case I imagine.  I wondered if arc would automatically handle spherical projections, great circles etc though - I'm not sure how to do that! (or is it simpler than I think?)
I'll try near_analysis (though note it isn't present in arcview which which I may need this script to be compatible).  Also am I right in thinking it requires that the features be (i) in a table and (ii) that that table doesn't already have a NEAR_ANGLE field?  I need to calculate multiple angles per feature (e.g. between each feature and n other objects)
CrispinCooper
I'm now using brute force...
def angle(pointlist):
    # calculates using cosine rule: A^2 = B^2 + C^2 - 2BC cos a
    # a = arccos ((B^2+C^2-A^2)/(2BC))
    # but multiply by 180/pi to convert from radians
    A_vector = pointlist[0] - pointlist[2]
    B_vector = pointlist[0] - pointlist[1]
    C_vector = pointlist[1] - pointlist[2]
    A2,B2,C2 = map(square_length_of_vector,(A_vector,B_vector,C_vector))
    B,C = map(numpy.sqrt,(B2,C2))
    side_ratio = (B2+C2-A2)/(2*B*C)
    if side_ratio > 1: # possible on sharp angle due to rounding errors
            return 0.
    elif side_ratio < -1: # possible on blunt angle due to rounding errors
            return 180.
    else:
            return 180/numpy.pi * numpy.arccos(side_ratio)
...shame if arc doesn't have a way of doing that that generalises to spherical geometry, though.
ChrisSnyder
Honored Contributor
while searchRow:
    partIndex = 0
        pointCounter = 0
        while pointObj:
            pointCounter += 1
            if not pointObj:
                if pointObj:
        partIndex += 1
CrispinCooper
Ah, that's probably what I want then - thank you!
DavidStrip
If you are going to be computing this a lot and efficiency matters, you can do slightly better by observing that
   [INDENT]a · b = |a| |b| cos(theta)[/INDENT]
where · is the dot product, |a| is the length of a and theta is that angle between vectors a and b.
Rearrange and you get
[INDENT]theta = arccos((a · b)/(|a| |b|))[/INDENT]
