Arcpy da Editor confusing
17141
26
07-30-2014 01:43 AM
Geography
Hi all,
I'm still new to arcpy and python. PLEASE can somebody explain why the first two lines of code create a runtime error, but the last two lines run fine?
>>> with arcpy.da.Editor(workspace) as edit:
...     edit.startEditing(False, True)
Runtime error
  File "<string>", line 2, in <module>
AttributeError: 'Workspace Operation object' object has no attribute 'startEditing'
>>> edit = arcpy.da.Editor(workspace)
THX!!
Tags (3)
RiyasDeen
May be this helps.
import arcpy
import os
fc  = str(sys.argv[1])
templine = fc + "_line_temp"
workspace = os.path.dirname(fc)
fields = []
for f in arcpy.ListFields(fc):
  if f.type != "OID":
  fields.append(f.name)
arcpy.SplitLine_management(fc, templine)
arcpy.DeleteFeatures_management(fc)
# if feature class is not in feature dataset then use arcpy.da.Editor(workspace)
with arcpy.da.Editor(os.path.dirname(workspace)) as edit:
  edit.startEditing(False, False)
  edit.startOperation()
  with arcpy.da.SearchCursor(templine,["Shape@"]) as sc:
  with arcpy.da.InsertCursor(fc, ["Shape@"]) as ic:
  for row in sc:
  ic.insertRow(row)
  del ic
  del sc
  edit.stopOperation()
  edit.stopEditing(True)
arcpy.Delete_management(templine)
Geography
I'll mark it as correct answer, even so I think that this approach would be against the advice from the help:
Cursors should be scoped to a single edit operation.
Or does it mean something else.
Again my best thanks to you Riyas!!
ToddUlery
First thought, not a solution yet, but you do need to nest your actual edits inside the edit sessions. I think its ok to have a search outside, but if there are updates, they need to go inside the operation.
Riyas Deen suggests this already. Just wanted to stress that at minimum it should be considered. I am looking into edits with topology feature datasets.
ToddUlery
I might even suggest not setting the edit session inside of the search. Set variable outside for search, and then call the session and then establish your search loop/update. Again, another thought.
ToddUlery
Still a litle confused about the env object.
env = EnvVar()
I assume you are setting this within a function you created. Need to look at that.
Geography
Todd many thanks for your reply's!! Why are you concerned about the env object? As you can see from the 1st code section (which I posted at
Geography
THANKS EVERYBODY for the fruitful discussion. Unfortunately I won't be able to look into your suggestions for the next couple of days, but I promise to take a closer look on all hints and suggestions you gave to me!!
