Arcpy da Editor confusing
17107
26
07-30-2014 01:43 AM
Geography
Hi all,
I'm still new to arcpy and python. PLEASE can somebody explain why the first two lines of code create a runtime error, but the last two lines run fine?
>>> with arcpy.da.Editor(workspace) as edit:
...     edit.startEditing(False, True)
Runtime error
  File "<string>", line 2, in <module>
AttributeError: 'Workspace Operation object' object has no attribute 'startEditing'
>>> edit = arcpy.da.Editor(workspace)
THX!!
Tags (3)
Geography
Thanks Riyas!! So you're suggesting I should avoid the insertcursor, because the help files talk about
Edit sessions and cursors
Cursors should be scoped to a single edit operation. This means a new cursor should be instantiated and released for each operation. This is very important when editing rows returned by a cursor because the rows are tied to a specific state of the geodatabase. Avoid using a cursor across multiple edit operations. Doing so can result in unexpected behavior and data loss.
when using them? If so, how could I insert multiple records then?
DanPatterson_Retired
once the da.*cursor is established, they use the for row in cursor syntax   See the da.updatecursor ArcGIS Help (10.2, 10.2.1, and 10.2.2)‌ example, they use "for row in cursor" syntax
Geography
Right Dan. You can see from my code above that I'm using it already . My problem seems to be the nesting of the "with edit" and "with cursor" structure. Otherwise, are you suggesting I could do the whole "cut, copy, paste procedure" within a single updatecursor?
You could give it a try if all the operations are being performed on a row by row basis
RiyasDeen
try replacing your code line 13 through 18 with below, suspect this should work. Also make sure you are able to edit the feature class from arcmap independent of your script just in case.
with arcpy.da.Editor(env.wd) as edit:
    #  use False for unversioned data
    edit.startOperation()
    with arcpy.da.InsertCursor(env.wd+r"\\TopoTestSet\\FGK_t0_Line", ["Shape@","LineType"]) as ic:
        for f in fl:
            ic.insertRow(f)
    edit.stopOperation()
    edit.stopEditing(True)
Geography
Again many thanks!
Riyas I tried your suggestion, unfortunately it stops with the same runtime error. I'm confident that I can access, and edit the data, because the 1st section of the above code works.
Dan I'll consider your suggestion more seriously - it might be an even better solution. But I've to admit that I don't know if  it's possible to update one single part feature (one row) into many single part features (many rows).
See the deconstruct option within the da.updatecursor section
RiyasDeen
Hi Mate,
managed to create a working sample for you. Attached folder contains a fgdb and toolbox with script tool.
Hope this helps you.
ToddUlery
fc  = str(sys.argv[1])
templine = fc + "_line_temp"
workspace = os.path.dirname(fc)
This was the part I was trying to get at. The object being used as the env for edits.
If you try to find attributes for the obj that you have set as the edit env, you wont.
The method above is setting the edit on a simple string path referencing the GDB. All of the work arounds have been successful using the edit with a string.
This method works great.
Geography
Again many thanks Riyas! I took a look at your code, its good and I think it does solve the task. However, I was looking for code using the with statement together with edit. Something like:
best regards
