I am confused as to why the arcpy.CreateReplica doesn't work when my script gets a list of versioned layers and puts them into a variable to load into the function verses me hard coding versioned layer fields into the script and it working fine. Any ideas?
import arcpy
import os
# Local info
userName = os.environ.get( "USERNAME" )
pcVersion = "Desktop10.7"
in_data = ""
# Data connections
ws = r"C:\Users\%s\AppData\Roaming\ESRI\%s\ArcCatalog\server.sde" % (userName,pcVersion)
gdb = r"C:\Users\%s\AppData\Roaming\ESRI\%s\ArcCatalog\local.sde" % (userName,pcVersion)
rName = r"TEST"# % (userName)
in_data = ""
arcpy.env.workspace = ws
dataList = arcpy.ListDatasets() + arcpy.ListFeatureClasses()
for dataset in dataList:
desc = arcpy.Describe(dataset)
if desc.isVersioned:
if "__ATTACH" in desc.name:
print ("Removing __ATTACH")
elif "NEO.DBO.cities" in desc.name:
print ("Removing NEO.DBO.cities")
elif "NEO.DBO.P_AlignmentSheet_test" in desc.name:
print ("Removing NEO.DBO.P_AlignmentSheet_test")
else:
in_data = in_data + '"%s",' % (desc.name)
print desc.name
in_data = in_data[:-1]
print in_data
try:
print("BuildReplica...")
arcpy.CreateReplica_management(in_data, 'TWO_WAY_REPLICA',gdb,rName,'FULL','CHILD_DATA_SENDER',
'USE_DEFAULTS','DO_NOT_REUSE','GET_RELATED', '','DO_NOT_USE_ARCHIVING')
print("BuildReplica done")
except Exception:
e = sys.exc_info()[1]
print(e.args[0])"NEO.SDE.ArchivedProposedMainline","NEO.SDE.Directory_Mwetzel","NEO.SDE.Misc_Companies","NEO.SDE.Misc_NEOFiles","NEO.SDE.Misc_OhioLayers","NEO.SDE.P_Integrity","NEO.SDE.P_PipeSystem","NEO.SDE.Parcels","NEO.SDE.Roads","NEO.SDE.TransmissionPipeline","NEO.SDE.StandaloneVersions","NEO.SDE.StandaloneLayers","NEO.SDE.Inspections","NEO.SDE.ArchivedLayers","NEO.SDE.P_AbandonedDevice","NEO.SDE.P_AbandonedPipe","NEO.SDE.P_AbandonedService","NEO.SDE.P_AlignmentSheet","NEO.SDE.P_CapitalProject","NEO.SDE.P_Coupon","NEO.SDE.P_CPArea","NEO.SDE.P_DrinkingWater","NEO.SDE.P_EcologicalArea","NEO.SDE.P_ExcavationDamage","NEO.SDE.P_ExposedPipeInspect","NEO.SDE.P_GasLeak","NEO.SDE.P_GasLeakInspect","NEO.SDE.P_IdentifiedIssue","NEO.SDE.P_LeakRepairs","NEO.SDE.P_LeakSurvey","NEO.SDE.P_LeakSurveyArea","NEO.SDE.P_NavigableWaterway","NEO.SDE.P_OtherPopulatedArea","NEO.SDE.P_OutsideArea","NEO.SDE.P_PipeCasing","NEO.SDE.P_PipeJobSeparator","NEO.SDE.P_PipelineMarker","NEO.SDE.P_REGULATORINSPECTION","NEO.SDE.P_SqueezeOff","NEO.SDE.P_StationStructure","NEO.SDE.P_StructureFootPrint","NEO.SDE.P_StructurePoint","NEO.SDE.P_Vault","NEO.SDE.P_WorkOrder","NEO.SDE.Atmospheric_Corrosion_Sites",
BuildReplica...
ERROR 000582: Error occurred during execution.
Failed to execute (CreateReplica).
The problem might be that in_data should be a list and not a string. You could change line 13 to be:
in_data = []
Then line 27 would be
in_data.append(desc.name)
And then comment out line 30 since you'll no longer need to slice the string.
in_data = []
