arcpy charts, setting the class break values?
1211
03-29-2021 10:39 PM
PeterMilenkovic
Hi All
I have a script that loops though a dataframe, runs a query and exports each subset to a feature table. Then i use arcpy.chart to generate calendar heat charts. I have set the classification method to 'natural breaks' but that gives be classes with heaps of decimals (see attached). Is there anyway to round the class breaks? I am exporting them to svg's so I guess I could do some sort of replace, but just wondering if there is an easier method?
PeterMilenkovic
Ok, I played around with it and the best solution could come up with was to:
  1. Read the svg
  2. Find the legend values by searching child nodes that contain '≤'
  3. Creating a list of legend values
  4. Creating a new list to round the legend values
  5. Modifying the original list (step 3) to re-insert a thousand separator ','
  6. String replace on the svg file
doc = xml.dom.minidom.parse(r"O:\users\pmilenkovic\PythonScripts\NotebookSandbox"  +os.sep + loc +'d_daily.svg')
    name = doc.getElementsByTagName('text')
    leg_lab=[]
    dec_pos = []
    for tx in name:
        if re.search('≤',str(tx.childNodes)):
            tx.normalize()
            leg_lab.append(str(tx.firstChild.data).replace(',','').replace('≤','').strip())
    leg_lab_replace = []
    for ll in leg_lab:
        leg_lab_replace.append(round(float(ll)))
    leg_lab_to_replace = []
    for ll in leg_lab:
        if ll.find('.') == 4:
            leg_lab_to_replace.append(ll[:1]+','+ll[1:])
        elif ll.find('.') == 5:
            leg_lab_to_replace.append(ll[:2]+','+ll[2:])
        else:
            leg_lab_to_replace.append(ll)
    #input file
    fin = open(r"O:\users\pmilenkovic\PythonScripts\NotebookSandbox" +os.sep + loc +'d_daily.svg', "rt")
    #output file to write the result to
    data = fin.read()
    for ll, nll in zip(leg_lab_to_replace,leg_lab_replace):
        data = data.replace(str(ll),str(nll))
    fin = open(r"O:\users\pmilenkovic\PythonScripts\NotebookSandbox" +os.sep + loc +'d_daily.svg', "wt")
    fin.write(data)
    #close input and output files
    fin.close()
PeterMilenkovic
  1. Read the svg
    leg_lab=[]
    dec_pos = []
    for tx in name:
            tx.normalize()
    for ll in leg_lab:
    for ll in leg_lab:
        else:
    #input file
    data = fin.read()
    fin.write(data)
    fin.close()
