ArcMap python data select dialog
1986
03-08-2021 01:19 PM
nimitz
Hi all,
I'm trying to create a script that will buffer a line. I'm going to place this in a custom toolbox that I made up.
I have the beginning of a script, and when I chose the input when I created it, the dialog won't allow me to pick a data file. I would like to choose a .gdb (or a shapefile) line and create a buffer. What am I missing?
I've attached a screenshot of the dialog.
Thanks for any help.
Tags (1)
DanPatterson
MVP Esteemed Contributor
isn't there 'FeatureClass' in the parameter properties section under Type?
... sort of retired...
DanPatterson
nimitz
Yes. I totally missed it.
Thanks Dan.
nimitz
@DanPatterson , it's been awhile since I've been on these boards. But, you're "still 'da man." Thanks again.
DanPatterson
No problem... you should move into Pro, the layout is a lot easier to follow
