ArcGIS Pro Notebook error
4660
03-11-2022 01:17 PM
MartyRyan
I am attempting to classify an image with a trained deep learning model that appeared to successfully work before. I enter the following as the first line in the Notebook:
from arcgis.learn import prepare_data, UnetClassifier
Instead of the next cell opening, I get this message:
ImportError Traceback (most recent call last)
In [4]:
Line 1: from arcgis.learn import prepare_data, UnetClassifier
File C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\__init__.py, in <module>:
Line 4: from . import features, geoanalytics, geocoding, geometry
File C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\features\__init__.py, in <module>:
Line 26: from .feature import Feature, FeatureSet, FeatureCollection
File C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\features\feature.py, in <module>:
Line 25: from arcgis.gis import Layer
File C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\gis\__init__.py, in <module>:
Line 34: from cachetools import cached, TTLCache
ImportError: cannot import name 'cached' from 'cachetools' (unknown location)
I cannot find any information on this Import Error (I am not proficient in Python) - what is missing, or how to fix it. Can anyone help?
I am working in ArcGIS Pro 2.9.2 and have installed the Deep Learning Libraries for 2.9
Thanks
DanPatterson
MVP Esteemed Contributor
could be an install issue
C:\...Your_install_folder ...\bin\Python\envs\arcgispro-py3\Lib\site-packages\cachetools
try
from your environment, it is installed with Pro 2.9
A related issue was noted previously
No module named 'cachetools' · Issue #36 · Esri/deep-learning-frameworks (github.com)
... sort of retired...
DanPatterson
try
MartyRyan
Dan, Thank you for responding - I was hopeful but I am still not getting beyond this error: I tried entering "from cachetools import cache" and still get an error:
In [1]:
Line 1: from cachetools import cache
ImportError: cannot import name 'cache' from 'cachetools' (unknown location)
I've tried other import functions and each one generates the same error. In some cases, instead of saying it cannot impart name "cache", it says cannot import name "cached" - this makes it even more confusing.
I am considering uninstalling the 2.9 DL Libraries for the second time and reinstalling them.
DanPatterson
Are you running the script from a cloned environment?  If so, it looks like your clone doesn't contain all the necessary elements and/or the DL package was not installed with the correct version or something went wrong.
Just in case
Esri/deep-learning-frameworks: Installation support for Deep Learning Frameworks for the ArcGIS Syst...
MartyRyan
Dan,
Thanks again - I just had a conference with my manager and the import functions work fine in his setup. We confirmed that I am not working in a cloned environment and my Python setup is fine -
His suggestion: Reinstall the 2.9 Libraries and if that doesn't work, do a new install of Pro 2.9 -
I'm uninstalling the libraries now and will see how it goes - thanks again
ÅsaBlomberg
Hi @MartyRyan ! Did you solve this? I have the same issue. Thanks!
