ArcGIS 10.1 arcpy Wall Reference
10440
19
06-26-2012 05:23 AM
JimBarry
From the description of this item on ArcGIS Online:
"This is a diagram generated automatically by a Python script that inspects the contents of the arcpy library as it is shipped with ArcGIS 10.1. It will not ever be an officially supported or maintained document, please refer to the ArcGIS 10.1 online help for an accurate, timely source of reference."
WaelYahya
test1111111111
MartinHvidberg
"This is a diagram generated automatically by a Python script ..."
Could you provide that script, so we can generate an overview for ver. 10.2
/M
JasonScheirer
Esri Alum
Regenerated here for 10.2.
Like I said in the comments before: The script wouldn't be particularly useful; it assembles the diagram by copying data from a variety of internal Esri sources that aren't available outside of our internal network.
GastonIzaguirre
Thanks for sharing this.
Is there or is posible to generate the Wall reference for ArcGIS 10.0 arcpy?
Thank you in advance.
Gaston.
JasonScheirer
Esri Alum
See attached for 10.0 version.
LindannePerdue
The link in your 11/19/2013 post regarding an object model diagram no longer works and the attachment to the 6/10/14 post says 10.2.1 on the bottom.  (AND IS EXTREMELY SMALL PRINT!!!)   I really need the 10.1 version if you still have it.  Thanks
JimBarry
The 10.1 version still exists. You can download it from here:
www.arcgis.com/home/item.html?id=20b26b39913c4661a2ba85674d07c2e3
GastonIzaguirre
Thank you very much!
MartinHvidberg
How about generating a 10.3 version - and releasing it with 10.3 ?
/M
