Hey all,
I'm attempting to work through a project where I take the geometry of a layer, and create a feature using that geometry with a set of attributes that do not match the fields of the destination layer. I attempted to check out the documentation, but it is not helpful for copying features from one layer to another.
How can I copy these features? I do not have access to Arcpy unfortunately or I would have this done already.
I'm open to any ideas!
Thank you in advance!
The final solution must not use arcpy at all? What format is your source data in and what format do you need the output in?
ArcGIS API for Python Geometry module:
https://developers.arcgis.com/python/api-reference/arcgis.geometry.html
ArcGIS API for Python Spatially Enabled Data Frame:
https://developers.arcgis.com/python/guide/introduction-to-the-spatially-enabled-dataframe/
