Alternative for Wildcards in Update Cursor
6881
12
04-20-2016 02:53 PM
DonDailey
I've got a point feature class of road intersections in which I used a script to create a field of joined road names from a line feature class. I've got to separate each road name into separate fields. I've been able to do that without much problem. But the road names were joined in more or less random fashion and now I need to rank the road names based on their type into their own field i.e. Interstates in the first field, US Highways in the second, state highways in the third, etc. All the highways begin with either Interstate, US or State.
I've tried doing a wildcard if ... else on the list created by the .split inside the update cursor but apparently that's not allowed. From searching it seems that regular expressions (which I've never used) might be my only hope. Anybody have any suggestions?
The code I used to split the field and place the road names into individual fields.
try:
# Import arcpy module
    from arcpy import env
#set workspace
    env.workspace = r"GDB"
# Local variables:
    fc = r"feature class"
#create update cursor to place values in fields
    fieldList = ["AllRoutes","ID_Road1_Cross","ID_Road2_Cross","ID_Road3_Cross",
                 "ID_Road4_Cross","ID_Road5_Cross"]
    with arcpy.da.UpdateCursor(fc,fieldList) as cursor:
        for row in cursor:
              cleaned = [x.strip() for x in row[0].split("&")]
              if len(cleaned) == 2:
                row[1] = cleaned[0]
                row[2] = cleaned[1]
              elif len(cleaned) == 3:
                row[1] = cleaned[0]
                row[2] = cleaned[1]
                row[3] = cleaned[2]
              elif len(cleaned) == 4:
                row[1] = cleaned[0]
                row[2] = cleaned[1]
                row[3] = cleaned[2]
                row[4] = cleaned[3]
              elif len(cleaned) == 5:
                row[1] = cleaned[0]
                row[2] = cleaned[1]
                row[3] = cleaned[2]
                row[4] = cleaned[3]
                row[5] = cleaned[4]
              cursor.updateRow(row)
except arcpy.ExecuteError:
    print arcpy.GetMessage(2)
except:
    print "Process did not complete"
DarrenWiens2
It's getting to the end of a long day and I'm having a hard time deciphering the problem on this one, so bear with me. If you want to know if a string starts with something, you can use the startswith() method:
if myString.startswith('Interstate'):
  return 'Interstate'
DanPatterson_Retired
I formatted your code Code Formatting... the basics++
DonDailey
Thanks for that Dan. I originally didn't see any way to do the code correctly.
DarrenWiens2
  return 'Interstate'
DonDailey
It looks like this is going to work. Thanks for the help Darren.
curtvprice
What happens when two interstates intersect? Can Field1 and Field2 both be interstates?
If so I suggest (inside the cursor with block) assigning a key and sorting, like this:
rds = []
for rd in cleaned:
    rdup = rd.upper()
    if rdup[0] == "I": key = 0  # Interstate
    elif rdup[0] == "U": key = 1 # US route
    else: key = 2 # state and other
    rds.append([key, rd])
# sort and place in fields
for k, rd in enumerate(sorted(rds)):
    row[k+1] = rd[1] # k = 0,1,2..
rows.updateRow(row)
DarrenWiens2
Just small edits:
- should be:
for rd in cleaned:
- and
curtvprice
Thanks Darren. Very much appreciate that - hate to have broken code posted!
Just curious... how many records are there in the road dataset to begin with?
DonDailey
I'm testing this out for a single rural county that has about 1,290 intersections on all public roads. I'm sure to do all counties it will be over 100,000 records. Right now I'm just trying to prove it can be done.
