Adding a feature class to terrain in python
7391
18
03-01-2016 09:38 AM
BethanyMarshall
Hello all,
I am having a problem with the adding feature classes to the terrain in my python code. I am trying to go from las files to a terrain. The code I am using is listed below:   The LAS_FD is the  Las feature dataset
arcpy.env.workspace = LAS_FD
fcList = arcpy.ListFeatureClasses()
params = "fcList shape mass points <None> 0 48 <none> false <none> <none>"
print "Adding feature classes to the terrain"
arcpy.AddFeatureClassToTerrain_3d (in_terrain, params)
Thanks in advance for any help!
Bethany
AdrianWelsh
MVP Honored Contributor
Is line 84 this one?
arcpy.AddTerrainPyramidLevel_3d (in_terrain, 'WINDOWSIZE', pyramid_level)
Maybe try using double quotes instead of single quotes?
BethanyMarshall
In ArcGIS, line 84 is this one:
I am thinking it must be a problem with my params, but I don't know what is wrong.
AdrianWelsh
Hmmm, maybe it has to do with the params. Maybe try changing shape to SHAPE and the "<none>" values to "<None>" to stay with the naming conventions. Sometimes Python is picky about upper and lower case.
Though it is possible that the ListFeatureClasses list may be causing the problem too.
I was looking at the example here:
Add Feature Class To Terrain—Help | ArcGIS for Desktop
and it seems that the feature class used for the AddFeatureClassToTerrain_3d is always one feature class versus a list.
DanPatterson_Retired
The documentation has a lot of preconditions which need to be met and confirmed
as indicated, I would check the documentation that Adrian listed.  Add Feature Class To Terrain—Help | ArcGIS for Desktop Then I would do a manual run through the process in ArcMap (ie not script) using the same inputs as you want to do with your script.  Once that works, you should compare the Results window to your code...in fact you can steal the results window outputs and use it to formulate the base of your code.
AdrianWelsh
Bethany, did you find where the error was happening?
BethanyMarshall
I actually changed the shape to SHAPE and the none to None values and I still got the error. I have tried to only input one feature class for the in_feature, but it doesn't seem to make a difference if it is one feature class or a list of feature classes. I have used the arc help, but their code is using a TIN and I am not using a TIN so their inputs are a little different.
I can't seem to figure out what the problem is with my code.
if shape is supposed to refer to the field in a featureclass/shapefile, it would be proper case as in Shape as would None
AdrianWelsh
Dan, that is interesting because the documentation in that link shows it as caps:
However, further down below,  it has Shape like you listed:
That would be nice if it were as easy as a case-sensitive issue... Let's hope!
tHat is sO conFusIng.... mayBe iT WaS caseFrEe DAy
