Add parent directory name to output feature class with os walk
3010
08-22-2022 08:32 PM
KyleSmiley
I have several folders under one big folder called "Counties". I'm attempting to use arcpy.da.walk to copy features. I'm trying to copy a shapefile called "Parcels" from each folder within the Counties folder. I run the code below and it works on one county folder, but then stops because the name of the shapefile is the same. So I now want to rename them in the same code block. Is this possble? I'd like to attach the name of the parent directory (which is the county name) so the output fc is "Parcels_Anderson", "Parcels_Bedford", etc.
Any help appreciated!
Here is the code:
workspace = "D:/Geodata/Cadastral/Parcels/Counties"
outgdb = "D:/Geodata/Cadastral/Parcels/Parcels_features.gdb"
walk = arcpy.da.Walk(workspace, datatype = "FeatureClass")
for dirpath, dirnames, filenames in walk:
    for file in filenames:
        infc = os.path.join(dirpath, file)
        desc = arcpy.da.Describe(infc)
        outfc = os.path.join(outgdb, desc["baseName"])
        arcpy.management.CopyFeatures(infc, outfc)
JohannesLindner
# if filename isn't equal to "Parcels.shp", go to next file
        if file != "Parcels.shp":
            continue
# if filename doesn't start with "Parcels", go to next file
        if not file.startswith("Parcels"):
            continue
# if filename doesn't contain "Parcels", go to next file
        if not "Parcels" in file:
            continue
Have a great day!
Johannes
JohannesLindner
With the os.path module:
        outfcname = os.path.basename(file).split(".")[0] + "_" + os.path.basename(dirpath)
        outfc = os.path.join(outgdb, outfcname)
With the newer pathlib module:
from pathlib import Path
        infc = Path(dirpath, file)
        outfcname = Path(file).stem + "_" + Path(dirpath).stem
        print(outfcname)
        outfc = Path(outgdb, outfcname)
        arcpy.management.CopyFeatures(str(infc), str(outfc))  # arcpy is old and doesn't know about Path
Have a great day!
Johannes
KyleSmiley
Thank you for that! I had one last thing I was trying to do and forgot to mention. In addition to above, is there a way to walk for a specific string?
maybe something like:
       for “Pacels” in filenames:
or
If filenames is “Parcels”
thanks in advance
 and so on….
JohannesLindner
            continue
            continue
            continue
Have a great day!
Johannes
KyleSmiley
Good morning,
thanks a ton! It worked!
Kyle
