Add field: error in executing tool
1318
06-06-2013 09:19 AM
ChrisBrannin
I am trying to add a field to all layers with multiple GDB's. Am I unable to collect a list of values and run addField tool on them?
import arcpy import os, math from arcpy import env   in_workspace = r"F:/test/testRnd" rndValue = "int(round(!ELEVATION!, -2))" fcList = [] fieldName = "SL_ELEV" for dirpath, dirnames, filenames in arcpy.da.Walk(in_workspace, datatype="FeatureClass",type="All"):     for filename in filenames:         fcList.append(os.path.join(dirpath, filename))  #Add new field arcpy.AddField_management(fcList, fieldName, "SHORT", "", "", "", "", "NULLABLE")
Thanks
ChrisBrannin
Thanks
I just needed to run another loop. This got it.
for dirpath, dirnames, filenames in arcpy.da.Walk(in_workspace, datatype="FeatureClass",type="All"):     for filename in filenames:         fcList.append(os.path.join(dirpath, filename))   for list in fcList:     arcpy.AddField_management(list, fieldName, "SHORT", "", "", "", "", "NULLABLE")
ChrisBrannin
Thanks
