Calling custom tools within a python toolbox
1641
06-06-2013 07:09 AM
KristenE
I have created several custom Python toolboxes with several tools in each toolbox. Within the execute method of a tool, I am able to call tools from another toolbox using the tool syntax (arcpy.tool_toolboxalias). But when I try to call a tool from a tool that is in the same toolbox, I get this error-
AttributeError: Object: Tool or environment <Tool_toolboxalias> not found
The error does not show up consistently. Sometimes the tool will work, and then after not changing any code I will get the error again.
I've tried importing the toolbox that I am working in (I would think that would not be necessary).
Has anyone else had this problem? Are you supposed to be able to call a tool from within the same toolbox? Should I be using OOP instead to call the execute method within the tool class?
