Add a Georeferenced Tiff to ArcMap 10.3.1 via Hyperlink or Current Extent
2832
02-17-2016 08:18 AM
AnnMarie_Bergmann
I have over one hundred georeferenced tiffs that I would like to add to an ArcMap session based on either 1) the current extent or 2) a hyperlink within an attribute table. Does anyone have any suggestions? Can this be done using Python?
DanPatterson_Retired
You can obviously create a python script to make a feature layer out of the files using Make Feature Layer—Help | ArcGIS for Desktop
The source of the files could be in a folder on disk, a reference to filenames in a field etc.
The question remains, do the feature layers have to intersect the current extent? be completely contained? etc.  This will make difference to the form of the code.
Also, how many times do you have to do this?  Daily? once? occasionally?
It almost sounds like a manual load would be faster, including any exclusion options
RebeccaStrauch__GISP
You should look at loading them into a mosaic dataset.
What is a mosaic dataset?—Help | ArcGIS for Desktop
Then you would only have to reference the one dataset and the imagery would automatically load no matter what your extent.  Better then having to load a different one each time.
XanderBakker
Esri Esteemed Contributor
If you don't have access to a Standard or Advanced license (required for creating a mosiac dataset), the alternative if to use  Create Raster Catalog—Help | ArcGIS for Desktop and create a unmanaged raster catalog. These draw fast and when you are zoomed out you will only see the extents of the rasters.
DEAF_PROBERT_68
Honored Contributor
Do you have ERDAS or ENVI ? Those will enable you to automate hundreds of imagery and it is way easier than doing in ArcGIS.
I have done that with many Landsat 8  in the past from southern California all the way to Western Texas and from Utah all the way down to Arizona, New Mexico.
