7-Zip could not be found in the PATH environment variable
2714
07-17-2021 08:12 PM
DimasPerceka
I dont know what exactly happen, a already set 7zip in my environment but if i run some script there are no 7zip in my environment.
here the error message :
(arcgispro-py3) C:\Users\User\Documents>python coral_reef_exercise_online.py https://downloads.esri.com/LearnArcGIS/update-real-time-data-with-python/vs_polygons.json C:\Temp\Work.gdb c7bdbfb02684459bae0e16e7bf3dbc5e C:\Temp\Coral_Reef_Watch.sd Coral_Reef_Watch
Starting workGDB...
Downloading data...
Creating feature classes...
Deploying...
  File "coral_reef_exercise_online.py", line 115, in <module>
    feedRoutine (url, workGDB, itemid, original_sd_file, service_name)
  File "coral_reef_exercise_online.py", line 63, in feedRoutine
    deployLogic(workGDB, itemid, original_sd_file, service_name)
  File "coral_reef_exercise_online.py", line 88, in deployLogic
    raise Exception('7-Zip could not be found in the PATH environment variable')
Exception: 7-Zip could not be found in the PATH environment variable
and this message proof that I have 7zip installed in my environment
Im very thanks if anyone can help me to solve this problem
curtvprice
You ran 7z from the windows command prompt. Have you tried seeing if the PATH variable is set correctly within the arcgispro-py3 environment?
This looks like part of a tutorial of some kind so my guess is you missed a step in the tutorial to set up this path within the arcgis-py3 environment.
dannyjp67
Have you found an answer
