Add @functools.lru_cache decorator to utils.fetchautocomplete
5851
02-23-2025 11:04 AM
Status: Implemented
HaydenWelch
MVP Regular Contributor
Issue Description
I have been working on re-writing a lot of the utils module in arcpy, as the code in there is an absolute mess and is part of the reason the Python Window in Pro is so terrible.
As I was going through it, I noticed that there is a `fetchautocomplete` function that seems to be called repeatedly everytime the cursor changes position to search the stack frame for autocomplete options that are handed to the renderer in ArcPro to build the auto complete popup menu.
In my testing, this function can take up to 200ms to run and that 200ms cost is paid every time the user types a '.' and it has to traverse the entire global stack for possible autocomplete options.
One Line Fix
The `utils` module already uses functools everywhere. In functools, there is this amazing decorator called functools.lru_cache. This decorator will cache function calls and their return values so if a function is called with the same arguments more than once, the cached value is used. Here's the proposed change:
@functools.lru_cache(maxsize=128)
def fetchautocomplete(code, string_index):
    """Function for ArcGIS desktop - fetches autocomplete candidates for
       python window"""
This will cache the 128 most recent strings passed to this function and their responses. That means the 200ms cost of searching autocompletes for `arcpy.` is only paid once. All subsequent `arcpy.` calls execute in ~100ns (a 100000000x speedup).
>>> %timeit fetchautocomplete('arcpy.', 6)
121 ms ± 1.1 ms per loop (mean ± std. dev. of 7 runs, 10 loops each)
# With lru_cache
134 ns ± 0.581 ns per loop (mean ± std. dev. of 7 runs, 10,000,000 loops each)
There are other functions in here that are constantly called in the window and can sometimes take up to 10s to execute, but those are problems for another day. For now I think getting a 100000000x performance boost on a frequently used function with one line of code and no additional imports is pretty good.
In my testing the largest speedup was when a function was called that traverses the current project datasources, e.g. arcpy.da.SearchCursor. First run in a large project took 15s, subsequent calls took 100ns. Without the cache, each time you typed `arcpy.da.SearchCursor(`, the 15s cost was paid.
This optimization will only work if the code string is exact currently as the entire contents of the REPL are handed to the `fetchautocomplete` function. In order to make this a general speedup, a custom cache would need to be created that associates the actual identifier with its autocomplete options. That way `*da.SearchCursor(` would be cached:
# cached
# Different cache entry for
with arcpy.da.SearchCursor(
The way the code is currently written, the full text of the input string and the index of the cursor is passed to each subsequent function. If instead, only the relevant part of the string was passed to each function and each of them maintained their own cache, the performance of the Python Window would increase with use. This is a bit out of scope of this Idea, as it would require a total re-write of the parsing functions in the utils module (something I will probably get around to eventually).
Note2: This is the current function call chain for the autocomplete parsing
Each of these functions is parsing the entire contents of the REPL
Note3:
There is a bit of an issue with arcpy functions that list the current map layers when you cache.
This was my biggest issue as again, for large projects this can take up to 30 seconds to load (and it blocks the main thread meaning you literally can't interact with Pro while it's trying to find out what layers are in your map).
The issue is that if you switch maps with an active layer cache, the layers won't update to the new map layers. Honestly, I prefer out of date layer lists to excruciatingly unresponsive load times that freeze the program, but I can see how this would cause confusion for users who don't think about that. The quick solution would be to remove layer autocomplete and just allow the user to drag the layer into the function. Other than that the whole layer autocomplete process would likely need to be re-worked. I can't even tell where it's happening in the original code...
5 Comments
MErikReedAugusta
For sake of use cases for ESRI:
The fact that the listing of map layers locks the main thread for so long drives me absolutely bonkers when using the Python window.  If I'm in the Python window, it's because I want some thing quick & dirty—emphasis, quick.  If the path to a Layer is simple, I likely know it and can just type it really quickly.  If it's nested a bunch of Group Layers deep, then I'm likely to drag it in, anyway, or pre-save it in a variable!
Worst, though, is that last approach where I have no need to trigger the autocomplete; I've already gone through that.  I would type straight through, give it that first parameter as my variable, and be on to the section with the field list, when the IDE catches up and tries to pull all the Layers into memory for the autocomplete that I've already gone past.  Cue main stack locking so I can't use anything else in Pro, like pull up the Fields View because I've forgotten the precise field name I was about to feed into the cursor.
I actually write the "with arcpy.da.SearchCursor(" bit out of order, now, to try to prevent the autocomplete from triggering on that first parameter.  In my experience, it's frequently too long a time sink for the "quick & dirty" operations in the Python Window.  I can't lose that mental or application focus for that long.
HaydenWelch
@MErikReedAugusta What's crazy is that this is basically a solved problem with type checkers like Pylance/Pyright/Mypy. Those all use Python to introspect types, docs, and autocompletion, but even with massive codebases tend to run hundreds of times faster than this. I think any map interaction from the linter/autocompleter should absolutely be explicitly set by the user (default off, and allow toggling it on). Having autocomplete is good and that should be kept on, but when it starts putting locks on my project and database it can be an insane invisible cost to using the window.
MErikReedAugusta
I absolutely agree.  I vaguely remember a post here on the Community where someone from ESRI chimed in with something to the effect of "the IntelliSense isn't going away, full stop."  That said, I think this is a point of unacceptable invisible cost, and adding a toggle seems like a perfect compromise.
Even if it has to be off by default, I could live with the bare minimum of a toggle that stops scanning my layers unless I explicitly ask it to do so.
HannesZiegler
We're working on a performance improvement to autocompletion for the list of layers (as in the example given with arcpy.da.SearchCursor). This status does not guarantee that the functionality will be in the next release, but development work has begun. Release cycles vary by product so make sure to check the product life cycle information to get an idea of when to expect the next release.
HannesZiegler
Fixed in ArcGIS Pro 3.7 - Intelligent code completion for layers in the Python Window is now very responsive, completing in less than half a second even for maps with a large number of layers.
