Selection not working after cutting polylines using line geometry in ArcGIS Desktop Python add-in
6086
03-07-2016 02:00 AM
AminulIslam
I am creating a ArcGIS Desktop Python add-in that has a tool to cut polylines of a layer by drawing lines across, just like the cut polygon tools in editor mode. I am able to cut polylines with my tool and save it but the problem is; I am unable to select properly any polylines of that layer after my cut operation. My add-in code is given below. onLine method of CutTool is called when the mouse button is double-clicked to finish drawing the line on the map.
class CutTool(object):
    """Implementation for PlugIn_addin.tool (Tool)"""
    def __init__(self):
        self.enabled = True
        self.shape = "Line"
    def cut_geometry(self, to_cut, sel_fid_query, cutter):
        Cut a feature by a line, splitting it into its separate geometries.
        :param to_cut: The feature to cut.
        :param sel_fid_query: Selected Query FID to cut.
        :param cutter: The polylines to cut the feature by.
        :return: The feature with the split geometry added to it.
        arcpy.AddField_management(to_cut, "SOURCE_OID", "LONG")
        geometries = None
        polyline = None
        edit = arcpy.da.Editor(os.path.dirname(to_cut))
        # Edit session is started without an undo/redo stack for versioned data (for second argument, use False for unversioned data)
        edit.startEditing(False, True)
        # Start an edit operation
        edit.startOperation()
        insert_cursor = arcpy.da.InsertCursor(to_cut, ["SHAPE@", "SOURCE_OID"])
        with arcpy.da.UpdateCursor(to_cut, ["SHAPE@", "OID@", "FID"], sel_fid_query) as polylines:
            for polyline in polylines:
                if cutter.disjoint(polyline[0]) == False:
                    geometries = polyline[0].cut(cutter)
                    polylines.deleteRow()
                if geometries:
                    for geometry in geometries:
                        insert_cursor.insertRow([geometry, polyline[1]])
        # Stop the edit operation.
        edit.stopOperation()
        # Stop the edit session and save the changes
        edit.stopEditing(True)
    def onLine(self, line_geometry):
        mxd = arcpy.mapping.MapDocument("CURRENT")
        df = mxd.activeDataFrame
        layers = arcpy.mapping.ListLayers(mxd)
        to_cut = None
        sel_list = None
        query = None
        # Find the selected layer and selected polylines of that layer
        for layer in layers:
                desc = arcpy.Describe(layer)
                if desc.shapeType == "Polyline" \
                        and hasattr(desc, 'fidSet') and desc.fidSet:
                    to_cut = layer
                    sel_list = desc.fidSet.split(";")
                    query = 'FID IN ('
                    for sel_id in sel_list:
                        if sel_id != sel_list[0]:
                            query += ","
                        query += sel_id
                    query += ')'
                    break
        if to_cut:
            self.cut_geometry(to_cut.dataSource, query, line_geometry)
        else:
            pythonaddins.MessageBox("There is no selection.", "Cut Polyline Features", 0)
        pass
WesMiller
Sounds similar to Limit combobox results to map extent you may need to create a polyline object then use a select by location
AminulIslam
Thanks for your reply. Actually, I am using the selection tool SelectionSelectTool16.png of the ArcMap to select lines splitted by my tool. So, selection using the mouse (after selection tool is active) is not working.
