safely stop bulk publishing layers from a datastore
2429
12-22-2020 09:42 AM
ChrisJensen
Does anyone know how to safely stop bulk  publishing the contents of a geodatabase once started?
by Anonymous User
Not applicable
Hi Chris,
The only way I can think of would be to go into Server Manager and manually stop the System/Publishing Tools service. This should cancel the rest of the publishing operations, at which point you can go in and delete the services you don't want anymore.
As for a built-in method, I don't think one exists. This could be a good enhancement request or Idea though.
-Calvin
by Anonymous User
Not applicable
Hi Chris,
-Calvin
ChrisJensen
Thanks Calvin.  I was fortunate to get a chat with tech support during the process.  He is going to request that enhancement you speak of.  We ended up waiting for the layer creation to complete, it didn't because the Portal logs filled up and crashed the process.  However, once the process runs, a "delete published layers" appears so they can all be deleted.  Then we went into portal admin and cleaned the logs.
ldeng
Chris and Calvin,
Thank you both for this posting!  Very helpful.  I was testing the bulk publishing  (by clicking the layers menu in data store properties). I have over 300 layers in the database thus want to stop after 100 feature layers created in 6 minutes (pretty powerful).  There is no such a tool, then I saw Calvin's solution and that saved the day.  ESRI does need to provide a tool to stop/pause the process.  I am on 10.8.1.  Wonder if 10.9 offer it?
Lang
Jamie_Leitch_CNF
we had a user do this and it is publishing over a thousand layers.  I want to stop this, but stopping the System/Publishing Tools service did not stop the publishing process as I can see the number of items in the datastore folder is increasing.  Is there any other way to stop this?
