Publish a feature layer from a registered folder
2262
02-27-2023 12:42 AM
MohammedElsayed
I have an issue when publishing from a registered folder to an enterprise portal, but it only allows me to publish map images only, and when I select the feature layer an error message says that  "layer's data source is not supported (web feature layer)"
Scott_Tansley
MVP Regular Contributor
That’s by design.  You have to use an enterprise geodatabase.  Files can only be edited by one process at a time, a windows limitation.  1 SOC is one process.  More than 1 soc would equate to many users.
Scott Tansley
https://www.linkedin.com/in/scotttansley/
Scott_Tansley
Scott Tansley
TanuHoque
@MohammedElsayed
Just curious, why do you want to enable 'feature layer' while publishing data, I assumed, off a file gdb? Is your goal to allow editing from web applications? Or just drawing on the client app using some web clients' advanced symbology option? or something else? thanks
MohammedElsayed
yes, my goal is to allow editing from web applications
