I am trying to understand if a service is set up as a shared or dedicated instance:
But I don't see the setting in server manager? What am I missing?
ArcGIS Server 10.7.1 (federated with Portal)
Solved! Go to Solution.
Was the service in the screenshot above published with ArcGIS Desktop (ArcMap / ArcCatalog)? Shared instances are only available for services published from ArcGIS Pro, and all services published from ArcGIS Desktop are dedicated by default.
Ah, yes it was. Thanks!
