Missing shared instance pool/dedicated instance setting
1501
11-01-2021 12:56 PM
forestknutsen1
I am trying to understand if a service is set up as a shared or dedicated instance:
https://enterprise.arcgis.com/en/server/10.8/administer/windows/configure-service-instance-settings....
But I don't see the setting in server manager? What am I missing?
ArcGIS Server 10.7.1 (federated with Portal)
ReeseFacendini
Esri Alum
Was the service in the screenshot above published with ArcGIS Desktop (ArcMap / ArcCatalog)?  Shared instances are only available for services published from ArcGIS Pro, and all services published from ArcGIS Desktop are dedicated by default.
ReeseFacendini
Esri Alum
forestknutsen1
Ah, yes it was. Thanks!
