General popups question...
1137
01-06-2023 09:53 AM
TychoGranville
Not sure which forum this should go in...
My powers that be want to have *everything* on one popup. Is there a way to on-click get a popup with all the layers that are underneath in one place instead of a normal sized one with the little arrows that you click through? With 50+ layers (of probably one to 20 lines each) you'll have to scroll forever to find what you want but they are getting more and more insistent as time goes by.
Tycho
jcarlson
Not exactly. You could try using intersections to grab other layers, but it won't be specific to the clicked point. If you wanted to get all the popups for one spot, the Lookup Instant App does that pretty handily.
- Josh Carlson
Kendall County GIS
jcarlson
- Josh Carlson
Kendall County GIS
TychoGranville
Thank you! That'll do the trick
