Filtering Issue with Referenced SDE Data in Enterprise Portal (v11.3)
1303
05-28-2025 10:41 AM
ChristopherRatcliff
Hello,
I have a quick question regarding an issue we've encountered while publishing our referenced SDE data to Enterprise Portal (v11.3). Specifically, we’ve observed different behaviors when applying filters to feature services and map services.
For example, our Storm Quality Facility layer uses symbology based on two attribute fields, as configured in ArcGIS Pro prior to publishing (see Fig. 1).
Figure 1Figure 1
However, once published, filtering the feature service becomes confusing (Fig. 2) — all filter options are labeled only with the name of the layer, making it impossible to interpret or select meaningful values. In contrast, the map service behaves as expected and allows for intuitive filtering with the correct values (Fig. 3).
Figure 2Figure 2Figure 3Figure 3
Is there an additional step we should be taking during the publishing process to ensure correct filter behavior for feature services? Or is this a known issue that might be resolved in a future Enterprise Portal upgrade?
Thank you in advance for your assistance.
Chris
DavidColey
MVP Frequent Contributor
I am finding the opposite situation at 11.4 when publishing a map image and feature access service from SDE for a Park Boundary layer that has a Primary Owner and Primary Maintenance attributes from which I created symbology as Field 1 Field 2:
The feature access service is honoring the Owner- Maintenance pair values to be filtered upon when selecting 'Owner' as the attribute to be filtered.
The map image service only honors the values of the Owner to be filtered upon when selecting 'Owner' as the attribute to be filtered.
I did publish the layer from the table of contents in Pro 3.4.3, not the map itself . . .
