I'm trying to change the workspace of all map services without republishing.
(We are migrating to the new SQL Enterprise GDB from the OLD SQL Enterprise GDB.
We need all map services to access new SQL Enterprise GDB data without republishing.
Suggestions for this are welcome 😃
Hello @Rodrigo_DaSilva
If you already have services published then wait for Pro 3.2 release, it will add the capability to change the data source of published services in the "Update Data Source for Map" tool.
If you cannot wait for Pro 3.2 release or if you cannot move to Pro 3.2 when it comes out, then I am sorry to say that you will need to republish the services.
However, you can use these steps to avoid having to republish services in the future and to avoid having to use the Pro 3.2 "Update Data Source for Map" tool as well.
1. create a DNS alias that points to the database server
example:
DNS alias "gisdb1.acme.com" resolves to the server hostname "sqldb1.acme.com"
2. SQL Server Instance runs on default port 1433
3. SQL Server Database Server has Static IP Address
4. In the Geodatabase Connection Files use the DNS alias - Example: gisdb1.acme.com
5. Resource all map documents with the new Geodatabase Connection Files
6. Republish all the Services
Now, the next time the SQL Server Instance and Databases need to move to a new Server Hostname you can simply change the DNS Alias to point to the new server hostname, this will not break the geodatabase connection files, therefore it will not break any ArcGIS Server Services that were published.
Example: SQL Server Instance & Dabases move from "sqldb1.acme.com" to "sqldb2.acme.com, and the DNS Alias changes to resolve to the new server.
"gisdb1.acme.com" resolves to "sqldb2.esri.com"
I hope this helps.
The docs say that this is possible via ArcGIS Server manager:
(A few paragraphs down from here, it says "This updates the registration for all services except stream services and ArcGIS Workflow Manager (Classic) services")
Although I've never found this to work 😞
I have found that this can be achieved via changing the configuration on the backend with the ArcGIS Server service stopped - it's not a supported workflow and can break things!
example:
I hope this helps.
Hi, thank you very much for your comments. @MarceloMarques and @A_Wyn_Jones
I will test in my test environment the actions mentioned.
But I'm glad to hear that a feature of this size is being envisioned by ESRI in the near future.
