Atribute alias in a map service not working
967
10-27-2023 06:02 AM
MarianHaluska
Hi, we are using ArcGIS server 11.1 to publish our layers that we have stored in a enterprise geodatabase (PostgreSQL 14.5.1 + spatial extention of ST_Geometry). Recently I noticed that some of our services do not show field aliases when identifiing fetures in a map. Services in question all support only default service type "Map" and were published using ArcGIS Pro 3.1.3
I have set up aliases for my layers inside our enterprise geodatabase so when a layer is added into ArcGIS Pro all atributes are correct.
I tried republishing the services in question but there is no change in displayed aliases. Also if I try to publish new service the problem is the same. What is more  confusing is that if I add only the layer of said service the aliases work fine.
Can someone help me pinpoint the cause of this issue.
Marian.
Sabina
https://community.esri.com/t5/arcgis-pro-questions/publishing-save-web-map-from-arcgis-pro-losts/m-p...
A workaround is to publish the feature service and then create the map in Portal.
