When I try to import my CAMEO data into pro using the new CAMEO Tools.tbx
(C:\Users\Adam P. Ingram\Documents\ArcGIS\Packages\CAMEODataManagement_f42c66\p20\ImportCameo.py)
I run into the following data error (the .zip file i'm using was downloaded directly from CAMEOfm V3.5.1😞
<< Begin >>
Running script Import CAMEO Data...
Checking output workspace...
Creating GDB: C:\Users\Adam P. Ingram\Documents\ArcGIS\Packages\CAMEODataManagement_f42c66\CAMEO Data V3.gdb
Extracting zip...
zip extracted
Adding Table: ChemicalsInInventory
Table Added: C:\Users\Adam P. Ingram\Documents\ArcGIS\Packages\CAMEODataManagement_f42c66\CAMEO Data V3.gdb\ChemicalsInInventory
Adding new fields...
Importing data...
Adding Table: ChemInvLocations
Table Added: C:\Users\Adam P. Ingram\Documents\ArcGIS\Packages\CAMEODataManagement_f42c66\CAMEO Data V3.gdb\ChemInvLocations
Importing data...
Adding Table: ChemInvMixtures
Table Added: C:\Users\Adam P. Ingram\Documents\ArcGIS\Packages\CAMEODataManagement_f42c66\CAMEO Data V3.gdb\ChemInvMixtures
Importing data...
Adding Table: Contacts
Table Added: C:\Users\Adam P. Ingram\Documents\ArcGIS\Packages\CAMEODataManagement_f42c66\CAMEO Data V3.gdb\Contacts
Importing data...
Adding Table: ContactsLink
Table Added: C:\Users\Adam P. Ingram\Documents\ArcGIS\Packages\CAMEODataManagement_f42c66\CAMEO Data V3.gdb\ContactsLink
Importing data...
Adding Table: Facilities
Table Added: C:\Users\Adam P. Ingram\Documents\ArcGIS\Packages\CAMEODataManagement_f42c66\CAMEO Data V3.gdb\Facilities
Importing data...
Error occurred while loading the data
Failed script Import CAMEO Data...
File "C:\Users\Adam P. Ingram\Documents\ArcGIS\Packages\CAMEODataManagement_f42c66\p20\ImportCameo.py", line 624, in <module>
main()
File "C:\Users\Adam P. Ingram\Documents\ArcGIS\Packages\CAMEODataManagement_f42c66\p20\ImportCameo.py", line 595, in main
tables_to_gdb(extracted_file_location, out_gdb_path)
File "C:\Users\Adam P. Ingram\Documents\ArcGIS\Packages\CAMEODataManagement_f42c66\p20\ImportCameo.py", line 407, in tables_to_gdb
t = create_and_populate_table(new_file, out_gdb_path, is_spatial, latField, lonField)
File "C:\Users\Adam P. Ingram\Documents\ArcGIS\Packages\CAMEODataManagement_f42c66\p20\ImportCameo.py", line 462, in create_and_populate_table
add_data(table, new_table, lat_field, lon_field, fields, null_fields)
File "C:\Users\Adam P. Ingram\Documents\ArcGIS\Packages\CAMEODataManagement_f42c66\p20\ImportCameo.py", line 560, in add_data
cursor.insertRow(new_row)
RuntimeError: The coordinates or measures are out of bounds.
Failed to execute (ImportCameoData).
<< End >>
Any ideas on why this failure to execute is happening? Where in the data is it going wrong? I also emailed Derek Law to see if he can connect me with the dev team to see if they have any ideas.
Thanks everyone!
Adam
Columbus, OH
