printing from Pro 2.2.12813 to the HP Design Jet 1055cm
594
12-26-2018 05:09 AM
JayYoung1
getting a protection fault error when printing from Pro 2.2.12813 to the HP Design Jet 1055cm
MichaelVolz
Esteemed Contributor
Is this set as your default printer?
Does this occur for all maps/layouts in all aprx files?
Are you able to print to other printers that are connected to this computer?
JayYoung1
Hi, thanks for your reply
Not set as the default printer
Happens to all aprx files
Can print to other printers
Can print from ArcMap 10.5 just fine
MichaelVolz
Can you try setting the HP Design Jet 1055cm as your default printer to see if that at least makes a difference?
Maybe you need to upgrade the drivers used for this printer from the manufacturers website (might want to discuss this option with your IT people).
JayYoung1
I'll give that a try and get back to you
