Does anyone push their Esri data to Intergraph I/CAD?
24785
41
07-30-2015 08:23 AM
KimberlyMeinert
I'm trying to find people to commiserate with who are Esri users who were tasked to roll map data to Intergraph's I/CAD system.  I have heard snippets about their new I/Map Editor toolbar that supposedly works with ArcMap now, but haven't found a whole lot of information on it.  There is no GeoNet in Intergraph-land...
Anyone?
MeganBirch
We've been working with the I/Map Editor tool bar for a couple months now.  And the labeling issues continue.  Labels are run off of annotation feature classes and one of the most frustrating issues we've been having is dealing with the road shields.  In ArcMap the shield labels look fine, but something happens during the publish process causes them to have large text and a tiny shield background. Has anyone done this successfully?
Label with text too large for highway shield.
GeraldEngstrom
I'm currently working on a large initial map role using only ESRI and the I Map Editor toolbar.  Its been a long road, used to use GeoMedia even though I'm an ESRI shop.
I'm also having issues with the labeling, specifically shields at this point as well so I share your misery.  I'm currently waiting for an email back with suggestions from Hex.
Will be watching this topic for updates from everyone.
Gerry
JoeBorgione
Have you guys talked to the Hexagon 'gis' guy about this?  I've just been sitting in the first two map build classes recently, so I can't really answer your question.  Seems like a reoccurring theme that needs to be dealt with....
Edited a little later:  in the classes I've sat through, the instructor mentioned using outside map sources for visualization purposes.  For CAD functionality you have to process the data into the Hexagon format: a process not unlike the orginal Spillman outfiles or the Versaterm VGI tool.  At any rate, would consuming an ArcGis server map or AGOL etc be a viable option in addition to the CAD map?
That should just about do it....
MeganBirch
We've been stuck in a bit of a loop with the Hexagon mapping team, working through some higher priority issues (i.e. getting out of county routing to work). They've not had anything helpful to say about the shield issue to date.
At the 9.3 version of Intergraph CAD they have, essentially, 2 mapping windows - the traditional one that displays the .map file and is used for verification and what is called the multi-source map.  The multi-source map can consume services and the extent can be adjusted to match that of the map window.  I think the general idea is to use the multi-source map for reference layers and preserve the .map file for functional layers.  However, based on the feedback from our dispatchers, there is a minimum level of labeling that is desirable for the functional layers and route shields are one of them.
MeganBirch
Oh, and we've noticed that there seems to be a scale limitation in the multi-source map.  I don't remember off hand what the particular scale level is, but the upshot is that they can't zoom in as closely on the imagery as they were previously able to.  We've got a ticket in with Hexagon on that as well.
JoeBorgione
Multi source- that's term I was forgetting.  I'm a lousy cartographer; which ever side of the brain that's artistic, well, those are the cells I killed off back in the 70's.  My dispatchers are used to simple maps, which is what I hope to give them in the .map side of the house, and then wow them with a multi source map.
LGalyen
Joining this conversation a bit late.  Hoping to keep this thread from dying as so may cross platform discussions seem to do for ESRI and Hexagon/Integraph/Geomedia. I also come from ESRI background and just last year took a position that required me to work with both ESRI and Geomedia for map rolls to a CAD system.
Wondering if anyone here has any updates to the threads above or have found a way to drive a Chevette as well as a Cadillac and learn to live with both.
JoeBorgione
Just gotta ask: which platform is the Cadillac?
My solution was completely self-serving: I left my 9-1-1 job and went to work in a 100% ESRI shop. (Best career move in all my years!)  From what I hear from my former colleagues, Hexagon continues to disappoint both as a CAD and mapping software.
Best of luck!
LGalyen
ESRI is the "Cadillac" in my view and I think for the original poster also......    Lucky you    Yes  I find Hexa support and platform V disappointing in both realms.  Sad to know the backside of all the services that are important fire, ems, law must rely on such mediocrity
Jodie_M_Gosselin
Can anyone provide me with a resource on how to best convert an Esri GDB into an Intergraph GeoMedia format? I'm finding very little on this topic. Will the Esri Interoperability Extension do the job as a quick convert? Or will I need to develop custom tools to do so? Thanks!
