INSP 360 files
5392
01-18-2025 11:06 AM
Shannon_Sprott
Greetings all, I am trying to use 360 images that are .insp format. Anyone had luck with these and using in ArcGIS Online, or importing/converting to Geotiff?
DanPatterson
MVP Esteemed Contributor
Support 360 view pictures - Esri Community
apparently it isn't but other suggestions are mentioned in the thread
... sort of retired...
agrescavage
INSP files are Insta360 Photo files, which is a proprietary format. To use these photos, you'd want to use Insta360 Studio to export these to another format, such as .jpg.
GeoTiff wouldn't be appropriate for this case, since its purpose is more for georeferencing aerial/satellite imagery.
Once these photos are converted, you can use them as Oriented Imagery, using GeoTagged Photos to Points, etc. They should be geotagged with the appropriate coordinates.
David
by Esri Contributor
This worked great for me.
I have an Insta360 ONE X2 and used the Insta360 Studio desktop app to export the 360 photo as a jpg. I then used to ArcGIS Pro 3.2 to run the Create Oriented Imagery Dataset tool then ran Add Images to Oriented Imagery Dataset
The camera heading attribute field was not populated by the tool. I edited table and changed the empty value to a 1. I used this value bc I saw it referenced in the ArcGIS Pro documentation.
ClarkSelby
You might also be interested in this 360° Photos Experience Builder widget for ArcGIS Enterprise and Online, available in the Esri Marketplace.
It was recently featured in Esri UK’s Site Scan for ArcGIS webinar.
(view in My Videos)
