Popup on button click
6563
03-02-2016 07:13 AM
TimWitt2
Hey everybody,
I am trying to recreate the google apps pop up on button click, seen here Google
Is there anything within leaflet that comes close to this?
A jsfiddle would be great!
Tim
Tags (3)
JohnGravois
that's not really an esri leaflet question so much as a generic HTML/JS UI question.
you might check out bootstrap button dropdowns http://getbootstrap.com/components/#btn-dropdowns-single .  another alternative is to write your own javascript to listen for when someone clicks on the button and programmatically display an entirely new <div>.
i'd be happy to review a fiddle if you want to give it a try and get stuck.
JohnGravois
can you provide a little more information?  your hyperlink just points to google.com.
also, it'd be helpful if you could show/explain what you've already tried, rather than just asking someone else to create a code sample for you from scratch.
TimWitt2
My bad, I use the apps so often I forgot that not everybody does.
I have attached a screenshot of the pop-up I was talking about.
I was looking at something like this Editing feature layers | Esri Leaflet  where you can click on draw a polygon and then a submenu pops up. Instead I would click on a button and a submenu with app choices comes up.
JohnGravois
TimWitt2
Those are great suggestions, I will see if I can get one of them going.
Thanks for offering help in case I get stuck. I will let you know.
