Creating a featurelayer from an array of locations
1757
01-21-2022 11:49 AM
BushraSyed1
Hello!
I was wondering if it would be possible to turn a 2d array of latitude and longitude into a featurelayer using esri leaflet? Would this be difficult to accomplish? This is what the data looks like:
var data = [
        { "latitude": 59.441193, "longitude": 24.729494 },
        { "latitude": 59.432365, "longitude": 24.742992 },
        { "latitude": 59.431602, "longitude": 24.757563 },
        { "latitude": 59.437843, "longitude": 24.765759 },
        { "latitude": 59.439644, "longitude": 24.779041 },
        { "latitude": 59.434776, "longitude": 24.756681 }
by Anonymous User
Not applicable
LeafletJS is pretty open-ended here with a few ways you could accomplish this. But with the esri-leaflet plugin there is no concept of a "client-side-only" FeatureLayer (but there is in the ArcGIS API for JavaScript).
Back to LeafletJS itself, you can use layer types such as `Marker`, `Circle`, or `CircleMarker` with each of your objects in your data array.
https://leafletjs.com/reference.html
JayJohnson2
You could use Add XY Coordinates in ArcMap to convert the table of coordinates to points, and then share the result as a map.  Leaflet can be used to publish it, but isn't required.
by Anonymous User
Not applicable
